Where does the metal heat shieild go on the 1986 VFR750?
Discussion in 'General VFR Discussions' started by Old86-VFR750, Aug 13, 2016.
  1. Old86-VFR750
    Old86-VFR750 New Member
    Near Toronto
    My apologies if this is in the wrong forum. I wasn't sure where I should put this... anyway.
    I have a metal heat shield for my 1986 VFR750 and I can't remember where it goes. I think it sat behind the rear exhaust pipes to protect the shock... anyone remember for sure or can you take a picture of it on your bike? I checked the manual and online and can't find anything.
    This is what it looks like.
    Thanks.
    Mounts to frame between rear headers and shock. Should have lower rubbers and rubber isolated collars on top.
    Like it looks like it does...
  3. speed
    speed New Member
    Harbor Oregon 97415
    Ya know let dig out my books, it's probably been 5 years since i looked at them lol, i dont use the shield since i have custom exhaust but i will look for you
  4. Old86-VFR750
    Near Toronto
    Thanks everyone... I'll need to crawl under there and look. But I think I know what you mean.
  5. squirrelman
    With limited access to that area, you probably won't be able to install the shield unless the engine is out of the frame. :disturbed:
  6. Old86-VFR750
    Near Toronto
    I found where the heat shield went today. I was swapping out the swing arm and saw it went in front of the shock.
  7. speed
    speed New Member
    Harbor Oregon 97415
    Yes, you are correct, I should have known that
  8. Old86-VFR750
    Near Toronto
    No problem. I didn't remember at all. I just looked and saw two holes.
