where does the round white electric connector attach?
Discussion in '5th Generation 1998-2001' started by TA-Rocks, Jul 6, 2020.
  1. TA-Rocks
    TA-Rocks New Member
    Gettysburg, Pa
    Where does this connect? Thank you. Also Gas tank hoses configuration. Its been off for a while.
  2. rhoderage
    rhoderage New Member
    Nova Scotia
    bottom of airbox
  3. raYzerman
    raYzerman Member
    Millgrove, ON
    Looks like Map sensor connector, right rear corner.
  4. Terry Smith
    New Zealand
    Given where that is, my guess is that it is the connector for the vacuum solenoid for the flapper valve actuator, uppermost of the circled plugs. upload_2020-7-8_8-30-40.png
  5. squirrelman
    whatever terry sez
  6. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    Here's a screenshot from the VFR800 Service Manual, page 5-52
    It appears that the White 2P (2P means "two pin" connector) is connected to the Intake Air Temperature Sensor.
    For further confirmation of the connector, the two wires that run into this plug are listed as "G/O" which is Green with Orange, and Gr/Bu which is Gray with Blue.
  7. rhoderage
    Nova Scotia
    yes, bottom of airbox
