Where does this hose go ????
Discussion in 'Introductions' started by markw46, Jan 13, 2008.
  1. markw46
    markw46 New Member
    2003 VTEC, I lifted my tank and while working under there I noticed a hose disconnected. It is black, about 1/2" diameter with a white plastic fitting on one end that looks like it slips into some plastic housing. It is on the left side and runs near the throttle cable bracket ??? It is a drain hose because the other end leads to under the bike. Please help me stick my hose somewhere, preferably the right place !!!
    NOW THAT'S a new pick-up line!!!:eyebrows: :cool:
  3. Action
    Action New Member
    Albuquerque
    Sounds like the over flow drain line.
    A white plastic connector hooks the bottom of the line to the rest of the drain hose.
    Action
  4. markw46
    markw46 New Member
    Thanks Action
    You pointed me in the right direction. I didn't see the connection place because I didn't remove the tank. You got me feeling around and I found the loose end.
    Thank you,
    Marko
