Where to get a Frankenbolt?
Discussion in 'Mechanics Garage' started by 98stage2, Mar 16, 2011.
  1. 98stage2
    98stage2 New Member
    Durham, NC
    Guess I didn't have one tight enough and it vibrated out... anyone have a spare one laying around?
  2. 02 VFR Rider
    02 VFR Rider New Member
    what is a franken bolt
  3. Keager
    Keager Member
    the bolts are the ones that look like they come out of Frankenstein monster's neck. (and that is pronounced Fren-ken-steen) also found on the F3/900RR's of the day. I'll take a look and see what I have when I get home.
  4. 98stage2
    98stage2 New Member
    Durham, NC
    Those Frankenstein looking bolts that protrude off of each side of the bike, holds the cowl on I believe (can't remember for sure, I never have mine on).
    Thanks Keager. :cheers:
  5. Spike
    Spike New Member
    seem them on Ebay once in a while, might want to set up a search that will tell you if any are listed
  6. betarace
    betarace New Member
    Middleburg, VA
    Ron Ayers has them. Shipping is expensive
  7. safetypro10
    safetypro10 New Member
    Dallas, TX
    Please!
    Go to the hardware store and get you some 6mm X about 1.5" long Stainless Flathead (I prefer allen myself) bolts and some aluminum tubing that just fits over it. Cut Al tubing to length to leave desired amount sticking out. Costs you about 25 cents in bolts,and about 50 cents in tubing. Buy a couple of extra. I finally went with about 1" long, like my frankenbolts short.
    Larry
  8. squirrelman
    Unless you're doing what those long bolts were designed for--strapping bungee hooks from your luggage--there is a wide creative choice of hardware options for this spot, every one looking better than stock.
  9. Keager
    Keager Member
    ah crap. Got home late last night & won't have time tonight either (anniversary). Will look on Friday....hopefully...
  10. 98stage2
    98stage2 New Member
    Durham, NC
    I like the creative fixes, I'm wanting to keep the bike as original as can be so I'll need the original Frankenbolt.
    Thanks again Keag
  11. squirrelman
    Sometimes those "all original" goobers rattle my pans !!
    Honda installed the wrong bolts, no one knows why. If the pope is not infallable, neither is Honda, and we can all find examples. They should have supplied the longer bolts as a "touring option" in a plastic bag under the seat, which would have significantly improved the bike's appearance, and i don't think many would dispute that.
    No need to make the same aesthetic mistake the company did just to be a conformist.
  12. ZenMoto
    ZenMoto New Member
    Moorpark, CA
    Somewhere I still have a package of the quick release version from Sargent that I never installed on my 5th gen. ...I could look for them tonight if you'd like.
    Sargent Cycle Products - Fast Access Quick Release Pins
    You can have them for cheap if you want them. ...but like others have said, you can get a lot of standard hardware that will work if you don't need the extra length for bungee cords!
  13. 98stage2
    98stage2 New Member
    Durham, NC
    I appreciate the offer, if I can't find an original I may take you up on that.
    I'm not usually a stickler for keeping a bike (or car) all original, just for some reason on this bike it's what I want. Not being a conformist.... just doing what makes me happy. I think that's all you can ask of a person.
  14. Badbilly
    Don't worry, be happy.
  15. ZenMoto
    ZenMoto New Member
    Moorpark, CA
    No worries at all. If you want it correct, just order new ones. Part number 90116-MBG-000 (about $12.00ea from servicehonda.com, look under "Rear Cowl"). ...don't forget the 8mm washer that goes there too: 94102-08000 ($0.38ea). :)
    http://www.servicehonda.com
  16. Keager
    Keager Member
    Looked where I would of had it. Had extra panel clips, screws & nuts for the battery, but no frankenbolt. Sorry.
  17. 98stage2
    98stage2 New Member
    Durham, NC
    That's cool man, thanks for looking.
  18. betarace
    betarace New Member
    Middleburg, VA
  19. donald branscom
    donald branscom New Member
    Guerneville CA
    Looks like a Bob Dylan copycat avatar.
    Matrix, Bob dylan all copy cat ideas.
    http://www.youtube.com/watch?v=qcm0rG8EKXI&feature=related
    I like original ideas.
    At least you know how to get actual part numbers and not just call a bolt a Franken bolt, and think people will know what you are talking about.
  20. FourOhs
    FourOhs New Member
    Coldstream, BC
    Funny, I came here three years late to the party after losing a Frankenbolt and doing a search. The first thread I found was this one. In my VFR-experience, having bought my 4th-gen in 2000, most people know what a Frankenbolt is just because they're so obviously straight out of Frankenstein's neck.
    Thanks, folks, for the non-OEM alternatives, and the OEM part numbers as a non-non-OEM alternative. ;)
