Where to purchase stuff like this?
Discussion in 'Mechanics Garage' started by GreenOnion, Jan 2, 2009.
  1. GreenOnion
    GreenOnion New Member
    So, does anyone know where i can purchase items for a motorcycle to go in the spot circled in the below picture? Thanks!
  2. dskelton
    dskelton New Member
    Fitzwilliam, NH
    accessory mounts
    I'm not exactly sure what you're asking, but if you're lookinig for mounts for accessaories, GPS, camera, MP3... I believe Ram Mount make a system that bolts into the stearing head.
    RAM Mounting Systems, Inc.
  3. betarace
    betarace New Member
    Middleburg, VA
  4. SilverSurferRWB
    SilverSurferRWB Member
    Bay Area, CA
    If you're looking for a mounting point for accessories then try Tech Mounts: VFR Stem Mounts
  5. RVFR
    I'm not sure anyone should be putting anything there.. ;)
  6. GreenOnion
    Well, as you can see the previous owner of this bike put a little girly lookin clock in the hole on my bike. I also just saw a picture of a GPS mounted in that hole in a picture of a VFR in the classified's section...
    So, I was just looking for stuff like that to put there. The clock the guy put in mine is dead, so I was looking for something to replace it. Besides, I don't know if the clock is sun bleached or what.. but pink is not lookin good to me. :p
  7. DAN-SLO
    DAN-SLO New Member
  8. NorcalBoy
    That location is typically used by knowledgable riders to install a techmount, or ram mount, providing a stable and convenient location for a whole range of very useful accessories. It is also the primary mount location universally chosen by steering damper manufacturers.
  9. Spike
    Spike New Member
    sometimes you can also install a Powerlet outlet there for GPSs or Radar detectors or both
    then if you mount the unit(s) to your bars, you don't have to worry about the cord getting hung up on anything or whether you have enough cord to go lock to lock on your clip ons
  10. Tightwad
    Tightwad New Member
    Powerlet for sure, unless you are running camera or GPS or similar that you want on a post there. I made my own mount for the GPS, and use that spot for the Powerlet kit.
  11. Packman
    Packman New Member
    Arlington, WA
    I have a ram mount installed there for my gps and another ram mount on my clutch resevoir for a camera. The ram mounts work great and look pretty clean when you dont have gear on the bike.
  12. OTTOMAN
    OTTOMAN New Member
    Olympic Peninsula, Wa.
  13. Slothrop
    Slothrop New Member
    northern lower Michigan
    That would be a great spot for a bud vase. But maybe that would be too girly lookin...
