Which mod's first?
Discussion in 'General VFR Discussions' started by SJC, Nov 4, 2009.
  1. SJC
    SJC New Member
    Adelaide South Australia
    Hi guys and gals,
    I have a brand new 09 vfr that is as stock as a rock.......... So which mod's should I do first and lets start with the cheap ones first.:lol: I've not long brought the bike so the expensive one's will have to wait a little while.
    I've heard things like the flapper and air box mod's but what do they do, I know the pipes will be the first large thing done but as of yet I'm not sure which ones I'll go for.
  2. steven113
    steven113 New Member
    Pensacola FL
    If you want to do cheap mods first popular ones are
    1. pro grip 699 gell grips
    2. 19mm tail rise plate from thurn motorsport
    3. K&N air filter
    4. If you are interested in quicker turn in after rising the tail raise your fork tubes 5mm
    5. EBC brake pads
    The best money spent would be Keith codes book "twist of the wrist 2" or even better yet go do an instructional track day or two.
  3. havcar
    havcar New Member
    Denver CO
    That color scheme looks great, South Africa only or did the European market get that aswell? I was thinking white with black was the only color available outside the U.S.
    Back to the topic at hand. Of all the mods I've done to my bike I think that going down a tooth on the front sprocket is the best money I ever spent. It does a great job of bringing some power back to the low and mid-range. It also does a nice job of smoothing out the VTEC transistion. Both of of those issues were a big problem for me. It seemed like the bike was running with the choke on under full throttle from about 4000rpm to 6000rpm. Most bang for the money at $40 parts and 1hr of labor. A half hour in the hands of a mechanic.
    Your going to start noticing some surging at off idle speeds(parking lot), not as a result of doing the -1f mod, just bad stock fuel mapping. That can be dealt with using a power commander but don't do that one untill after you've completed everything else your going to do first.
  4. steven113
    Pensacola FL
    I knew I was leaving something out... Thanks havcar!
    gearing should be first on the list(either -1 on the front or +2 in the rear)
  5. mello dude
    Romania
    Wow thats a beautiful bike....
    -- Mods? I would say - crack off a couple thousand miles and see what tugs at you...
    MD
  6. betarace
    betarace New Member
    Middleburg, VA
    I would upgrade the rider's skills. Go to California Superbike School (Kyalami) best money you will ever spend on a bike mod.
  7. SJC
    SJC New Member
    I do need to improve my riding skills, but that's just a little too far to go :rofl:
    I live in OZ.:smile:
  8. VFRBenny
    VFRBenny New Member
    Oakland, Cal.
    Bar risers and custom seat(for starters). And yes, EBC pads and some nice tires.
  9. havcar
    havcar New Member
    Denver CO
    The book Twist of the Wrist that steven113 mentioned is a great source if you can take the time to practice all of the lessons.
    Also I neglected to mention one other inexpensive mod. In terms of just sheer looks ( if it matters to you) is a CW fender eliminator. About $50 and easily installed.
  10. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    god those gold rims look awesome!!!
    its amazing how much different the bikes can look with blacked out components and gold wheels, while still having exactly the same color plastics...
    anyways, on with the mods:
    plus 1 on the fender eliminator
    if you dont ride with male passengers much, ditch the passenger grab handles and pick up the inserts from bikebandit.com they're only a couple bucks each...
    pull out the snorkel and flapper ... free :thumbsup:
    pick up a bmc filter, like 50ish deppending how good of a deal you can find...
    o2 eliminators... 330 ohm resistors from radio shack, almost free :thumbsup:
    you can gut the cans for cheap, or pick up any slip on you want...
    i rode with gutted cans for a while and now have 2bros. dont listen to anyone with the, "this exhaust sounds the best" blahblahblah bullshit, you have a vee4 and any exhaust you put on it is gonna sound awesome!
    after you get comfortable working on your bike pick up a 98-99 header or a motad header.
    finally imho the best mod ever... a powercommander. either get a new pc5 and an auto tune module or get a pc3 with a custom tune... either way it is the best performance upgrade you can do for any vtec vfr!
  11. betarace
    betarace New Member
    Middleburg, VA
    my bad I saw S.A. in your profile ans assumed wrong....
    good news
    :: Welcome to Super Bike School ::
  12. TimRav
    TimRav New Member
    NE Ohio
    Congrats on that beautiful VFR!
    A few suggestions for fairly inexpensive appearance mods:
    -Fenderectomy (trimming stock) or eliminator kit
    -Remove fork's reflectors
    -Remove passenger grab handles and insert cover tabs
    -Have exhaust up pipe heat shield, clutch and front brake levers, rider and passenger footpeg assemblies powdercoated black
    -Smoke or darker color windshield
  13. havcar
    havcar New Member
    Denver CO
    I did the same thing...knew that that was an Australian flag and then
    let the S.A. trip me up. So I should ask, is that color set-up for the Australian market only?
    Appoligies for my confusion.
  14. Alaskan
    Alaskan Member
    Alaska
    aftermarket saddle (my very first mod!)
  15. SJC
    SJC New Member
    Don't worry about the confusion about country guys:biggrin:, have fixed up my profile so that should make it easier.
    Now so of you have suggested 19mm tail rise plate from thurn motorsport, what does that do to the bike? I know, stupid newbie question.:tongue:
    And also to pull out the snorkel and flapper, now is there a "how to" do this or is it just pull the parts out?
    Also CandyRedRC46 mentioned o2 eliminators... 330 ohm resistors from radio shack, almost free. Again what does this do and is there a "how to".
    BTW this bike is a stock 2009 model so the colors and rims are standard for OZ.
    Here's another pic for you........
  16. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    ok lets see if i can knock this out...
    1st 19mm tail rise:
    by raising the back of the bike you are changing the suspension geometry of the bike. as in the rake and trail etc. the fork itself will be more upright instead of kicked out. also this marginally shortens the wheelbase. this will make the bike steer quicker and feel easier to flick from side to side. theis is a good mod if you plan to take your bike to the track. also it will give you some more lean clearance. usually raising the back comes at the expense of some stability, but the vfrs are very stable bikes and i believe most here will tell you that bike is still rock solid after adding the tail riser...
    2nd snorkel and flapper removal
    this is done by lifting the tank to gain access to the airbox.
    loosen the two front screws attaching the tank to the frame. leave the back two on as the tank will pivot on a hinge connected to those back two bolts. prop the tank open. the snorkel is as easy as pulling out... the flapper is a vaccuum actuated solinoid attached to a flap in the airbox by a hook.
    unhook and disconnect the actuator, plugging up the remaining vaccuum line.
    3rd 330 ohm radio shack resistors
    basically most bad fueling tendancies of the newer vfrs can be traced back to the bikes going in and out of open and closed loop fuel injection. this can be remidied by simply eliminating the o2 sensors.
    find the 2 o2 sensors pluged into your headers and trace them back to where they connect to the harness. diconect them and plufg a 330 ohm resistor in each of their places... there are a million how articles on this. just do a quick search so you can see the deatiled pix, as you have to be sure where to plug in the resistors or youll get an fi light. you can just purchase the eliminators from dynojet for like 20 bucks a peice if you want to...
  17. mello dude
    Romania
    Damn I like them gold wheels!
    Hey Candy - bike bandit have those seat insert for a 5th gen?
    MD
  18. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
  19. winaje
    winaje New Member
    Melbourne, Australia
    Yay, I'm the first Aussie to welcome you with your new bike. Looks awesome BTW. First thing I would do is lift the forks through the triple clamps by about 5mm, this improves cornering handling etc, and changes the feel of the bike quite a bit FOR FREE.
  20. SJC
    SJC New Member
    Thanks for the welcome winaje:smile:
    Just looking around for a "how to" on the flapper mod, have already looked into the resistors and they seem pretty easy. Also going to go to the web site to look into the tail raisers. Thanks guys:thumbsup:
    I'm guessing from the link above that the snorkel is part number 3 and the flapper is number 8. Once I have taken the flapper out does that leave a hole or do I just disconnect it and leave it in?
