Will experienced DIY mechanic post list of necessary tools/accessories/equipment for maintanence/rep
Discussion in 'Mechanics Garage' started by Dirtylocks, Jun 26, 2012.
  1. Dirtylocks
    Dirtylocks New Member
    Southern Colorado
    Hello Viffer community!
    Totally newbie here with a 99 5th gen sittin in my garage due to unidentified electrical problem.
    I already posted about that and have some steps to take.
    This post is to see if we can reel in an experienced bike mechanic who can post a list of "must-haves" for VFR maintanence and repair.
    Please be specific as possible.
    example: instead of "tool kit", tell us what range of tools, measurements, etc. would be ideal...maybe even a particular brand?
    Thank you to anyone who steps up to the plate!:cool:
  2. ridervfr
    Have 13 more drawers along with the red boxes...:tongue: more to follow
  3. tinkerinWstuff
    welcome to the forum from northern CO
    :wave:
  4. Dirtylocks
    Southern Colorado
    Epic avatar my fellow Coloradoan.
    Lovin da yellow colorway too.
    Stay outta my neck of the woods for now, historic wildfire down here.
  5. mello dude
    Romania
    This should work..... :biggrin:
  6. Dirtylocks
    Southern Colorado
    Haha, thanks
  7. tinkerinWstuff
    Guess it was your turn. We've already roasted 80,000+ acres and around 250 homes.
  8. orion3814
    orion3814 New Member
    fayetteville, ar
    i dont c ne metric in there.. and your missing this.. [​IMG]
  9. OOTV
    OOTV Member
    I'll tell you what I have now but a lot of my tools went missing when I left them in my parents garage when I first moved out. My sisters ex-boyfriend used to "borrow" them to work on his car but somehow forgot to put all of them back! I've replaced a few of the more needed items but it will be a while until I'm back to square one. I used to work on my all my vehicles when I had the time and space to do so, but a lot less now, but I'm not afraid to tackle a project if need be. Most of these items were acquired over the years of working on various vehicles and some of them would only apply to a specific vehicle. Most of this list is from memory so there may be some missing items in the list.
    Metric socket set(s) 1/4", 3/8", and 1/2" drive sizes 6MM-19MM, (6pt. and 12pt.) plus a few larger sizes for special nuts/bolts 22MM~46MM (Larger sizes vary not full range of sizes)
    1/4", 3/8", and 1/2" Drive Ratchets, Large Breaker bar too
    Torque wrench (3/8 drive)
    Assorted length and size screw drivers, Phillips and flat head
    Hex wrenches (4mm-8mm) both socket type and T-handle
    Impact driver and mallet, rubber tip hammer, regular and ball peen hammer
    Air compressor with various attachments, air chuck, impact driver, blow nozzle, air ratchet, etc.
    Feeler gauges
    Tap and Die set (metric) 3mm - 12mm (.5-1.25 pitch)
    Multimeter/volt meter
    Pliers, channel locks
    Wire cutters, flush cutters
    Snap ring pliers, spreader pliers
    Vice grips (sm, med, lg)
    Crescent wrenches (sm, md, lg)
    Scratch awl, center punch
    Safety wire tool and safety wire (different wire gauges)
    Chain breaker
    Flywheel puller
    Brake bleeder (Mity-vac)
    Wire brushes, nylon brushes
    Sand paper various grit sizes
    Dremel tool with various tips, cutting wheels, sanding discs, polishing wheels, wire wheels, etc.
    Files flat, round, half moon course and fine
    Fork seal driver, bearing drivers
    Fly wheel holder
    Timing light kit
    These are the things that went MIA...
    Needle nose pliers, straight and angle tip (sm/lg)
    Magnetic pick up tool
    Magnetic parts bin/bowls
    Compression tester
    Spring compressor(s)
    Calipers
    Floor Jack/Jack Stands
    Cylinder honing kit
    Piston ring compressor
    Valve spring compessor
    Nut driver set 4MM-10MM
    Spring puller (think scratch awl with a hooked end)
    Pin Spanner
    Ignition wrenches
    These are the few items that I like to have on hand
    Lock-Tite (Red/Blue)
    DOT4/5 brake fluid
    Motor Oil - typically what's currently in the bike(s)
    Anti-freeze
    Contact cleaner and/or PJ-1 Super Cleaner (Careful on some painted surfaces)
    Silicone, Gasket sealer
    Grease (various types)
    Measuring cup
    Gas can
    Drip Pan/Tray
    Nitrile gloves/Mechanics gloves
    Shop rags
    Hand cleaner
    Hose clamps various sizes
    Zip ties various lengths/widths and colors
    Tie downs/Tie straps
    Fuses various sizes
    I hope this helps.
    Cheers!
  10. Rubo
    Rubo New Member
    Instead of of buying lots of specialty tools that you may need or not I suggest buy as you need bases.
    Foremost important.
    1.Multimeter -don't cheap out here you want continuity with sound ,ohms etc.most useful tool trying to diagnose a problem
    2 Battery tender
    3.Torque ranch -Don't buy 20-200lb buy 10lb to 100lb smaller the range more precise.Almost all engine torque specs don't exceed 100lb.
    4.Metric socket set-don't bother any other since your VFR is all metric. (I bought killer socket set from harbor freight and quality just unreal considering I paid 18 dollars)
    5. Various size screwdrivers.
    Start with these. I suggest buy Harbor freight tools.They are cheap and great quality.Can't beat them in quality.
    Check this out
    13 Piece High Visibility 1/2" Drive Metric Deep Wall Impact Socket Set
    kick ass deal.I got this set and can't believe the quality $21.99
    Sizes: 10mm, 13mm, 14mm, 15mm, 17mm, 18mm, 19mm, 21mm, 22mm, 24mm, 27mm, 30mm and 32mm
    Pretty much covers all sizes for your bike.I specially like that it includes 21+sizes.Most sets don't go higher then 19mm.
    I have become fan of Harbor freight.
  11. DaHose
    DaHose New Member
    Napa, CA.
    Here is a list of stuff I consider essential
    Metric socket set in 1/4 and 3/8 drive
    1/4 and 3/8 drive ratchets
    1/4 and 3/8 extension sets
    1/4 and 3/8 breaker bars
    Set of standard length combination wrenches
    Set of long length combination wrenches
    Decent multimeter
    12V test light
    Metric t-handle allen wrench set
    metric allen socket set
    Decent screwdriver set
    Decent pliers set
    Assortment of hammers
    Drift punch set
    Decent circlip pliers set
    Assortment of strap wrenches
    Set of picks
    For a torque wrench you need to either find a reasonably priced GearWrench digital model off of Amazon. If you don't trust yourself to take proper care of a digital wrench, then you should purchase a split beam torque wrench. Get one with a pivoting head. It really does help.
    I am also another big fan of Harbor Freight's line of Pittsburgh tools. They are very affordable, high quality and come with lifetime replacement warranties. If you have an HF nearby, go there with the list above and you can get everything in one trip, from one store.
    If you have space in the garage, I HIGHLY recommend at least a 10 gal. compressor and a basic air tool set as well.
    Jose
  12. ridervfr
    Me likes my 3/8 butterfly along with my 1/4 3/8 speed handle and my ratcheting magnetic T-Handle screw-driver. I could be shamless and plug some brand, but will restrain from it. No pictures sawwy. T-Handles are nice as they give you superior feel compared to ratchet wrenches, but me loves ratchets and have a big selection of em! T-Handles are dedicated sized size tools in various sizes, K&L and Motion-Pro sell them, I have some gold plated Snap-On ones that will be buried with me as I dont believe in being an organ donor or passing cherished things on to ingrates. :evil:
  13. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    About the only thing I'll add is to have a set of 6 point wrenches and sockets. Some of the cheaply made 12 points may not grip the bolt/nut precisely and end up rounding the head. Harbor Freight is a great place as long as you realize their limitations.
    I also recommend at least 2 torque wrenches: a 1/4" drive for the small stuff that measures in inch pounds, and one that goes up to 100 ftlbs for the bigger stuff.
    And a set of ratchet combination wrenches can be very handy for quickly getting out bolts you can't get a regular ratchet on.
  14. TOE CUTTER
    Fridge full of beer, can't believe you guy's forgot the beer.
  15. kennybobby
    kennybobby New Member
    i like Rubo's advice to buy them as you need them--that way you're not overwhelmed and out of money (tool poor). Use the money you save that would go to the dealership to buy what you need to do the job, e.g. oil filter wrench, funnel, catch pan to do an oil change.
    On the multimeter look for one that has a diode test function in addition to voltages ac & dc, millivolts dc, resistance, continuity (beeper), high currents ac&dc, and low currents. It's nice if you can find one that measures currents up to 20 amps. Fluke makes some nice one$.
    Theoretically with the OEM tool kit under the seat you can field strip the bike and do all the basic access and maintenance tasks, e.g. fairing removal, spark plugs, chain adjust, etc. Being the OCD mo-fo that i am, one of the things that i like in that kit is the "philips" screwdriver, which is really not philips but is JIS. It has a different profile and specification and won't cam-out the heads of the JIS screws like a philips will.
  16. OOTV
    OOTV Member
    I did say I was going by memory and ironically I was drinking a beer when I was typing...I did realize I forgot to list chain lube.:smile:
    As for the comment, "Buy them as you need them", I agree and that is why the tool set I have has grown quite a bit. One thing that helps is to look and read the repair manual before you tackle any project and see if they list any special tools. Then go out and buy them and read the manual again and see if you missed anything. Can't tell you how many times I was in the middle of a tear down realizing I was missing that one special tool. It's frustrating to have stop what you're doing, run to HF, Sears or wherever you buy your tools just for one special tool. Of course being men, we tend less to read a manual and just do it!
    I should add that the Tap and Die set I had bought from HF didn't seem to work as well as the one Craftsman I bought. Also the print on the side of the tool was very hard to read, on the Craftsman it was very legible and easy to see. So yes, some tools from HF are not as up to snuff as other more well known brands. YMMV
    Cheers!
  17. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Be aware that the factory service manual states torque readings in ft-lbs. in rather low numbers (like 9 ft-lbs.). Most torque wrenches don't go that low on the ft-lbs. scale so you will need an in-lbs. torque wrench that does.
    Just multiply the low number by 12 and you have the in-lbs. equivalent.
    Example:
    9 ft-lbs. x 12 = 108 in-lbs.
  18. Pliskin
    Pliskin New Member
    Morris County, New Jersey
  19. Scubalong
    Is it a Maintenance 101..........? :rolleyes:
  20. tinkerinWstuff
    you beat me to it.
    I was gonna say buy beer and make friends with a neighborhood wrench
