Will not go into gear
Discussion in 'Mechanics Garage' started by thomas flynn, Apr 30, 2019.
  1. thomas flynn
    thomas flynn New Member
    VFR 750. Clutch works fine. starts fine. as soon as I try to put it in gear it cuts out.
    Gearbox is not stuck as if i put the bike in first with engine off and try to turn back wheel it does not turn until I pull in clutch lever and then the wheel spins.. Was thinking it was clutch but have just disassembled and put back together to confirm plates were not stuck together. Im convinced it is electrical as if i ease it into gear slowly it cuts out before any mechanical clunk.
    What year? Sounds like a side stand switch that thinks it's down.
    NorcalBoy likes this.
  3. thomas flynn
    Sounds like your problem to me.
  5. thomas flynn
    wonder if it could be the neutral switch ?
  6. sudolea
    sudolea New Member
    Belgium
    Roeselare
    Looks "the hard way" to me. Why not rule out electric problems first ?
    +1 Actually you mean clutch lever switch?
    Even more likely.
  8. thomas flynn
    Was the side stand switch. It was disconnected, must have done this when I was replacing the fuel pump points. !!! Thanks to Captain 80s
    :thumbs:
  10. fink
    fink Member
    Clutch diode away?
