Hello, I have found reasonably priced Varadero oem panniers with oem top case but I am not 100% sure they will fit 6th gen without some kind of adaptation? I have attached images of the panniers and top case. To me they look pretty much the same. Can anyone confirm that they can be mounted on VFR ? Thanks Ivan
Well, to answer my own question, Varadero oem panniers will perfectly fit VFR 6th gen oem pannier brackets, only thing that is different are the "Varadero" stickers, everything else is identical. Beside Varadero's oem panniers CBF 1000 also has the same but they lack the heat shields, everything else is the same. Cheers Ivan
