wiring help! vf700f with pics
Discussion in '1st & 2nd Generation 1983-1989' started by ic2283, Mar 4, 2011.
  1. ic2283
    ic2283 New Member
    just confused about the battery terminal hookup and the right and left hand control hook ups. I just need to know which colors for which nob. Sorry I'm a noob:crazy::crazy::crazy:
    Thanks!
    Which terminals go where? sorry I'm having a blonde moment
    which color goes on which !
    Same here which color on which
  2. crustyrider
    crustyrider New Member
    North Country, New York
    red on the positive side of the battery....
    on the right side...hook then up...and if the bike doesn't start switch them....
    the left side is your nuetral safety bike won't start unless you have it in nuetral, so same with that....theone you don't want to hook up backwards is the battery leads....
  3. ic2283
    ic2283 New Member
    so the other two on the negative side right?
  4. rpierce
    rpierce New Member
    Dayton, Ohio
    I have the exact same bike but I'm not sure what the extra wire is. I just see 2 hooked up to that fuse box and one on each terminal of my battery.
  5. rpierce
    rpierce New Member
    Dayton, Ohio
    Scratch that. The blue one goes to the left side of the fuse box now that i can see my pictures
  6. ic2283
    ic2283 New Member
    thanks for all the help! now onto the next problem, no spark after a new salenoid ! time to visit more posts and break out the meter
  7. squirrelman
    First, check all the fuses.
    After you test and eliminate the several wiring and component issues, then suspect the CDI.
    Refer to wiring diagram, find the proper lead, and test that +12 voltage gets to CDI when key is ON. If not then test the clutch switch.
