Wiring question...need help with my cluster
Discussion in 'Mechanics Garage' started by makenzie71, Nov 27, 2014.
  1. makenzie71
    makenzie71 New Member
    More questions concerning my Gen5 800 powered mini-buggy.
    I'm relocating the dash and am using two eight-conductor cables to handle it. The problem is that there are 17 wires going to the dash. I want to terminate the grounds at the frame near the dash to free up my needed conductors. Looking at the wiring diagram I'm pretty sure I know which ones I can bolt to the frame at the cluster but I would like it if someone else with a little more experience can confirm them for me.
    Thanks in advance!
  2. makenzie71
    FYI ~ If I'm looking at this correctly the green/black stripe wires are both common grounds.
  3. rjgti
    rjgti New Member
    regina sk
    had a fast look, that would be incorrect, the green wire on plug 2 is your ground point
  4. rjgti
    rjgti New Member
    regina sk
    had another look, g\blk is ground also as is green
  5. makenzie71
    Thanks! That's how I got it set up. I was pretty sure but sometimes I get my lines crossed looking at those black and white wiring schematics.
  6. rjgti
    rjgti New Member
    regina sk
    np, glad to help. was hard to see on my phone also
