New Life for an Old 86 VFR700
Discussion in '1st & 2nd Generation 1983-1989' started by Dr.Инженер, May 17, 2019.
  1. squirrelman
    so go ahead and reset them as close as possible to .005". much easier and quicker on your bike than later bikes. there is a possibility some valves were damaged by the lack of clearances. be sure to use a box-end wrench to loosen the adjuster locknuts.
    don't fret too much about exact crank alignment since u know that clearance can be measured at any point where the lobe is NOT pressing on the pad. also, at any crank position you can check one intake and one exhaust clearance.
    Dr.Инженер likes this.
  2. Dr.Инженер
    Dr.Инженер New Member
    Tennessee
    Yeah,, that moment when garage gnomes (kids) raid your garage and take the 10mm wrench from its perfect resting place. Now setting clearance will have to wait till tomorrow.
  3. NorcalBoy
    I'm pullin' for ya. I sure hope the valve seats aren't hammered dogshit and the valves aren't tuliped. Best of luck to ya!
  4. Diving Pete
    This is how you end up with at least 2 sets of tools... Mine took my feeler guages..
  5. Dr.Инженер
    Tennessee
    Yeah I'm puling for the bike also, I have little to no money in it, No loss to me just sad for the bike and then if it is fubar I have to decide repair, replace or sell out.
  6. NorcalBoy
    I don't need little rascals...I'm quite good of thinking too far ahead, start one thing, then get the crow shiny thing going and start fussing with something else. Next thing I know, I'm half done with three things and running in place. I literally stop everything I'm doing, clean up, and start over. When I am spending more time looking for things, rather than making any real progress, it's time to punt. Can only blame it on myself.
    squirrelman likes this.
  7. Dr.Инженер
    Tennessee
    got all intake set to .005 or as close as I can
    Dry-1:140 2:90 3:160 4:140
    Wet-2:150
    didn't bother wet testing 1,3 or 4 since adjusting clearance they look good.
    So.... thoughts?
  8. NorcalBoy
    I'd say you at least have something to work with. Came around pretty decent. I would say it would be worth a little effort to get it running at this point.
  9. squirrelman
    get it running and check #'s again after running a few miles.
  10. Dr.Инженер
    Tennessee
    Well that's a start, I'll take it... Gentleman I appreciate the help.
    Yeah, get it going and ride the piss out of it. That's good news.
  12. Dr.Инженер
    Tennessee
    Heck yea, pretty excited since this is the condition I found the bike in. sitting in some old country boys yard rotting. See the other bike, no clue what it was, rotting in the back ground also.
  13. Dr.Инженер
    Tennessee
    What in the? Not stock.
  15. Dr.Инженер
    Tennessee
    Yeah, I know just sharing for a good laugh
    I’ll have to source a complete used set. Too many Little issues with this set. Feebay has 3 different sets from a 1987 vfr750 between $100-$600. Anyone one of theses will work, correct?
    Any 86 or 87 VFR carbs will work. Try to get non-California to make it easier (less vent hose plugging), but either will work.
    That $100 set looks usable. The $164 dollar set are Cali.
    It's a bummer everyone insists on removing the plenum, there is a chance one of the fuel tubes could be cracked if it wasn't removed carefully. Especially if it was removed prior to extracting the carbs from the engine.
  17. Dr.Инженер
    Tennessee
    Oh dear. Who the FUCK was this PO loser?!
  19. NorcalBoy
  20. Dr.Инженер
    Tennessee
    I don't know him but what a story to tell if I can get this bike running, the condition it was found it, the valve clearance at "0", the copper fitting jammed in the carbs and now the swing arm custom modification....LOL...
