Wont idle after winter mothball
Discussion in '1st & 2nd Generation 1983-1989' started by Guest, May 6, 2004.
  1. Guest
    Guest Guest
    Hello Members,
    Fired up my 84 vfr750 for the summer. Wont idle and wont start unless full choke. Everything was fine when parked last fall. Thought it was bad gas so limped it to the station and topped off with 3 gals. Didnt help. Will run at 3000 and above but pull in the clutch and she dies. Owned for 20 years, first problem. Any suggestions? Thanks, Dave
  2. keny
    keny New Member
    Finland
    city of Karjaa, Finland North Europe
    I guess that the cabs need cleaning as the fuel does some buildup when it stands for a long time. I allways emty the cabs befor I put it in for winter, ither open dravn scruvs ore run it till stops.
