Wow, feels like a new bike!
Discussion in '5th Generation 1998-2001' started by brentlbaker, Apr 5, 2014.
  1. brentlbaker
    brentlbaker New Member
    Corinth, Texas, United States
    Got my bike back from the shop. Had Race Tech springs installed for my weight, new tapered steering stem bearings and heli bars.
    I could not have asked for a better ride, I absolutely love the new feel of the bike. I'm sure I will now be happy with this bike for many more years.
  2. bitterpil
    bitterpil New Member
    Northern Virginia
    Good deal. Yup. The bike gets even better after its setup for you and the at you ride.
  3. VFR777
    VFR777 New Member
    Kansas
    It's good to be you bro, eh :cool:
  4. Scubalong
    Yeah you will love her more when you have some personal touch to make the ride more enjoyable :thumb:
  5. brentlbaker
    I didn't realize how bad my stem bearing where until getting new tapered bearings. That combined with .95 fork springs and the bike feels and handles like a completely different bike. It is so much more responsive and better in the twisties.
    Wish I did it as soon as I got it.
  6. brentlbaker
    Feels even better know. The darn shop I loved so much put the helibars on backwards :( I guess they gave that part of the setup to the new guy who can't follow directions (or even look at them for that matter). They offered to switch it for free but did not offer to pay for the damage done (see below)
    Idiot ground off the tab in the kill switch that keeps it from spinning and over tightening. First clue was my throttle was sticky.
    I had to buy a new kill switch and that involved taking apart the front end to connect the new wires. All is good now, except i discovered a broken off bolt that holds a break line to the right side fork. Guess they probably did that too and didn't fix it. arrr.
  7. sunofwolf
    sunofwolf New Member
    Fix your own bike as much as possible, I don't trust many places to work on my bike. If you can do it yourself then do it!:bull_head:
  8. squirrelman
    Don't allow anyone (except yourself, maybe) to work on your bike unless he's sober and over 45 years old. That's just the way it is ! :worked_till_5am:
  9. brentlbaker
    You guys are both correct. Lesson learned. The guy at Helibars said that motorcycle repair shops are notorious for putting them on backwards and they never read the directions. He is 100% right.
    I am still glad they did the steering stem bearings though. That is a PITA! They did that and changed the fork springs to racetech .95 for $416 including the $115 springs.
    So I don't have much room to complain.
  10. VFR Love
    VFR Love New Member
    New York
    I got .95s installed on mine along with Gen-Mar risers. I'm 185 lbs and the bike sits much more upright between the 2 upgrades. A heck of a lot less dive under braking too.
    The idiots that did it at first used the incorrect length spacers (or none at all??) so the pre-load adjusters had to be cranked all the way in.
    So they did it again but this time decided to leave the stem bearings way under tensioned so there was a massive knock in the front end.
    I still have concerns a year later so I'm bringing it to a competent mechanic for the stem bearings and the rest of anything I plan on doing myself including putting in a relay for the heated grips instead of tapping them off the headlight.
  11. brentlbaker
    Sorry to hear you have had mechanic issues also :chaingun:
    I also weigh 185.
    Ya the bike is much stiffer up front and handles so much better.
    I use to hit hard on some DFW highway potholes but now it eats them up.
    It doesn't slam the front end down when you brake hard.
    I can immediately go faster through twisties (I'm sure a big part of this is because my old stem bearings where notched at center)
    It is the springs that should have been factory.
