Yuasa YTZ14S in a VFR800
Discussion in '6th Generation 2002-2013' started by VFR1200, Dec 1, 2018.
  1. VFR1200
    VFR1200 New Member
    Calgary, Canada
    I was wondering if anyone has put a Yuasa YTZ14S in to a VFR800 instead of a YTZ12S. A store is selling the 14S for cheaper than the 12S. Would there be any issues?
    Thanks in advance.
  2. Egg on Leggs
    Egg on Leggs New Member
    Birmingham, UK.
    Check the dimensions, the 800fi battery is taller than the vtec.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I quit putting Yuasa in anything after their prices went through the roof. I get mine from Wally World. They
    seem to last just as long and cost a whole lot less.
  4. VFR1200
    VFR1200 New Member
    Calgary, Canada
    My local stealer wants $265 CAD for a Yuasa battery. I have found them cheaper in the US, once you put shipping, USD to CAD conversion then it is not far off the same price.
    The dimension of the two batteries are identical. The YTZ14S is used in the VFR1200.
  5. skimad4x4
    France
    French Alps & London
    Do it!
    They are the same size externally so I would buy whichever is cheaper. The specs of the two batteries can be found in the official Yuasa battery catalog.
    http://www.yuasabatteries.com/wp-content/uploads/2017/12/Catalog-2018-Final.x78244.pdf
    Ps it takes ages to download - so wait ..
    Once you have the file you will see the detail specs of both batteries on page 7. Essentially the batteries are the same with the 14 holding marginally more capacity (11.2 compared with 11 amp hours) - so yes it might be marginally better at starting in extreme cold but who rides then?
    There is no reason to think swapping to a 14 will have any material impact on the charging system.
    Hope that helps
    SkiMad
    VFR1200 likes this.
  6. richieg66
    richieg66 New Member
    I always install the 14 as it's cheaper in the UK as well. Same size physically but higher capacity amps wise so what's not to like?
    Sent from my ONEPLUS A6003 using Tapatalk
    Merlot likes this.
  7. Bat-1
    Bat-1 New Member
    Aiken, SC
    I gave up on Yuasa's long ago. Stupid expensive and uneven performance in my experience. Last five batteries I've bought at batterysharks.com
    Stupid cheap and no issues with any of them. In all my bikes currently, though I'm itching to try out a lithium.
  8. Merlot
    Merlot New Member
    Philippines
    Angeles City, PH
    I did it. Cost a little more but gives the starter a better push. Fit was same as the normal battery, a win-win.
    VFR1200 likes this.
  9. VFR1200
    VFR1200 New Member
    Calgary, Canada
  10. Bat-1
    Bat-1 New Member
    Aiken, SC
    Just before Christmas I found a lithium for $90. Put it in my Buell 1125, which needs some serious CC amps to start that V-Twin. AGM batteries worked but were not confidence inspiring. After a cold week or two they wouldn't start the bike unless topped off on a tender.
    The lithium was the answer. Even if I don't ride it for a couple weeks it now starts two seconds after pushing the starter. Don't know about longevity but I'm sold so far.
    VFR1200 likes this.
