Zero Gravity Sport Touring - 5th Gen
Discussion in '5th Generation 1998-2001' started by austinaw91, Jul 26, 2019.
  1. austinaw91
    austinaw91 New Member
    Findlay, Ohio
    So after 33k miles, the stock windscreen had a bit of UV damage and never really provided the protection I wanted. After looking at my options, I found the Zero Gravity Sport Touring screen to offer the best wind protection without looking like a Gold Wing. Also, the smoke looks good!
    After a couple shorter rides, I feel like buffeting has been reduced slightly and that wind noise has been reduced a bit.
    Once I fit my 20mm risers, we will see how things work out.
    Overall, pretty pleased. Fit and finish seems good, but not OEM quality (nothing is...)
  2. PhoenixOO10
    PhoenixOO10 New Member
    Knoxville, TN
    I have the same wind screen! I think it looks amazing with the tint.
    I have helibars and am 6ft tall. The new screen deflects the wind into the chin on my helmet, rather than my shoulders and chest. I get more wind buffeting unless I sit strait up and keep my helmet in the clean air. It's not bad, but I might switch back to the stock just to compare again. If I was a little shorter or taller, it might work out better.
  3. austinaw91
    Findlay, Ohio
    After fitting my 20mm bar risers, I notice more buffeting around the helmet area. My options are 1) return this and locate a double bubble to bring the wind plane down to my chest or 2) get helibars/convertibars to put me higher into the clean air.
    Thoughts?
  4. PhoenixOO10
    Knoxville, TN
    I think it a depends on getting your seating position right then finding the right wind screen. I like the helibars a lot but I've never used the stock bars, so I can't compare the two. I also bought a nicer helmet that reduced some of the buffeting. I wish I had better insight for you, but I'm also trying to figure out this whole windshield thing.
  5. austinaw91
    Findlay, Ohio
    I actually just listed the ST screen for sale. Used for about an hour total. Ordered a DB so I will compare. Every rider is different with arm length and riding position as well as bar height so the options are endless.
  6. adk_finn
    adk_finn New Member
    Vermont
    I wish you were closer, we could swap and try them both. I have a double bubble, am 6'1", stock bars and pegs. It is ok, not too much buffeting but I also haven't used anything else on this bike. I am curious if the touring would be better, just not $100 curious.
