Zero Gravity SR Series OEM replacement Windscreen
Discussion in '6th Generation 2002-2013' started by 25thVFR800, Mar 13, 2019.
  1. 25thVFR800
    25thVFR800 New Member
    Toronto, Canada
    Hi, has anybody installed a ZG SR series (OEM fit) windscreen on their VFR.
    Is quality good, does it rattle around or is fit solid at higher speeds.
    Thxs
  2. Terry Smith
    I have the ZG double bubble on my 5G, can't criticise it at all, fit is great and function is much better than stock, probably adds 20km/hr to a comfortable cruising speed with less buffet. IMG_4265.jpg
  3. OCLandspeeder
    OCLandspeeder New Member
    I have one on my RWB 2007.
    It's ok. Thinner than stock so there is some space along the edges where it meets with the fairing, especially near the edges of the "wings" at the top of the fairings. If I had to do it over again I would get either the GIVI or just get a new OEM one. I prefer the shield to be thicker and more solid. Although mine never moved. The gaps do allow the edges of the fairing to screech any time some pressure is applied to the screen because the gaps let in dirt.
