6th generation clicking noise from engine
Discussion in 'Mechanics Garage' started by vincentb, Feb 17, 2017.
  1. vincentb
    vincentb New Member
    I have a 6th generation. Engine runs great. Wax unit works great but after engine warmed up and idle drops down to 1100rpm there is clicking noise from the left side of the rear engine. anyone familiar with this clicking noise? What's on the left that could be making this noise?
  2. 34468 Randy
    34468 Randy Well-Known Member
    You should try to attach a sound clip for us to listen to. Is the r]frequency of the clicking consistent with the RPM of the engine? What happens when it is in gear or not.
  3. GreginDenver
    GreginDenver Active Member
    Random clicking? Or clicking that is perfectly synchronized with (i.e. equal to) the engine RPM? OR... is the clicking occurring at 1/2 the indicated RPM (remember that the valve train items (camshafts, etc.) rotate at 1/2 of the crankshaft speed).
    It's worth buying a "Mechanic's Stethoscope" from Harbor Freight (dirt cheap). Looks like a doctor's stethoscope but has a pointed metal probe at the end so you can touch it to various points on the engine to figure out where the actual location/source of the clicking is.
  4. Allyance
    Allyance Insider
    East Bay, California
    Are you talking about idling in Neutral? That normal.
  5. vincentb
    vincentb New Member
    Yes in neutral. when the engine is reved up or riding is it very quiet.
  6. vincentb
    vincentb New Member
    only can hear the clicking while idle in neutral. when give it some gas or while riding engine quiet and runs great.
  7. vincentb
    vincentb New Member
    I suspect could be the CCT...
  8. Lint
    Lint Well-Known Member
    Simi Valley, Ca.
    Does the noise go away when you squeeze the clutch lever?
  9. Allyance
    Allyance Insider
    It is your transmission, this has been on another thread before.
