'96 VFR continues to die
Discussion in '3rd & 4th Generation 1990-1997' started by robertomolina2013, Jul 22, 2014.
  1. robertomolina2013
    robertomolina2013 New Member
    Hey guys, I've been having an issue with my 750, I've replaced the battery twice and today it died again. I'll fully charge the battery and it'll start and run fine for about two weeks. I'll jump the bike and it'll run for a short amount of time then dies again. Is this going to be an issue with my stator or R/R? Thanks in advance!
  2. Gundecker
    Gundecker New Member
    Yes . Test the Reg/rectifier. I bet it's bad.
  3. squirrelman
    It doesn't make sense to drop in another battery unless you test the charging system output at the same time.
  4. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    You need to go to this thread and read it. Pay specific attention to post number 9. Come back here and post some numbers.
    If you don't know how to do any of this stuff, just ask. We;re here to help. You need to make sure you have 2 things: A voltmeter (available at any auto parts store, Walmart etc. $20. And a battery charger).
    Report back with your findings.
    http://vfrworld.com/forums/showthread.php/39277-How-to-fix-common-regulator-Stator-failures
