almost done with my naked 95 750
Discussion in '3rd & 4th Generation 1990-1997' started by erbilabuc, Aug 24, 2014.
  1. erbilabuc
    erbilabuc New Member
    quick run down is gsxr tail, gsxr headlight, r1 rear sets, 600rr front end. gets ridden all the time so every 2-3 months i get to work on it. I need to make a panel to hide some of that wiring.
  2. FourOhs
    FourOhs New Member
    Coldstream, BC
    I like it. I don't think I'll go quite that far, but I'm trying to figure out what I want to do with my upper fairing. I've got the lowers off after doing some carb work and I'm leaving them off for the time being. This does, however, leave the bottom of the upper fairing looking like it's missing something, which, of course, it is.
  3. REEK
    REEK New Member
    Sacramento CA
    looking good. so how bout a few pics from different angles?
  4. erbilabuc
    only side shot i have.
  5. justinflatt222
    justinflatt222 New Member
    How hard was it to replace the tail and do you know where i can get a used gsxr tail i can find one?
    jflatt22
  6. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    +1, I want to see the exhaust side.
    What is that wiring or hose on the right side to bellow tank?
    It needs fixing.
  7. rustitution
    rustitution New Member
    Pennsylvania
    I'm also interested in how you got that superbike bar on that triple tree
  8. 6klub
    6klub New Member
    Fort Lauderdale, Florida, United States
    looking good, i'm diggin' the tail.
  9. erbilabuc
    The whole front end is from a 2009 cbr600rr and it all bolts on. The cbr600rr triple tree has indentions if you want to drill out to mount dirtbike bars. The wiring and hoses are there til i can figure out what to do. I havent worked on the bike in over a year but last thing i did was put a clear clutch cover window.
  10. nitramnottuh
    nitramnottuh New Member
    Looks nice.
    What did you do for an oil cooler as I cant see the original VFR one anywhere?
  11. ridervfr
    Belgium
    Nice build! Where are you FL? I am in South FL.
  12. erbilabuc
    Im from orlando but currently live in Hawaii and North Carolina. I took the oil cooler out and replaced it with a solid stainless steel line. Its all open to airflow so oil cooler can be bypassed.
