Bent connecting rod?
Discussion in 'Mechanics Garage' started by sfdownhill, Jun 29, 2016.
  1. sfdownhill
    sfdownhill New Member
    Vista, CA
    Hello gentlemen and ladies,
    I purchased a 2002 VFR on eBay. In the past I have owned a 1998 VFR and a 1994 VFR. I did all the maintenance on the VFR's myself, including fork seals and non-VTEC valve adjustment.
    The 2002 VFR in question has 22000 miles on it. The previous owner stated in the ebay posting that the engine had a bent rod. In emails and messaging he described the failure event as a loss of power while cruising on a freeway at normal speed, then the engine began running very rough, so he pulled over and stopped. I do not recall if he stopped the engine or it stopped running on its own. After stopping, he was able to restart the engine one time, but it ran very rough and would not keep running. Then it would not start at all. The previous owner was not mechanical, so he had the VFR transported to a mechanic, who checked the engine out and pronounced that it had a bent connecting rod. The previous owner did not ask how the bent rod was detected, nor was he able to recall what the mechanic said about a possible cause for a bent rod.
    *My question is "How can I confirm or disprove the diagnosis of a bent rod?"
    So far, I have drained the oil. Almost 3 quarts of oil drained from the engine. I did not see any metal particles or gray swirls in the oil. I have not yet removed the oil filter to cut it open for inspection - that is my next step.
    Before purchasing a used engine, I thought I'd poke around the bent rod engine and see if it really is damaged internally. A bent rod seems highly unlikely on a VFR with such moderate mileage.
    Thank you for any input you can offer.
  2. NormK
    NormK New Member
    With the plugs out can you turn the motor over by hand
  3. sfdownhill
    Vista, CA
    Thanks Norm - I'll pull the plugs and try to turn it over.
  4. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    With the plugs out, you can also measure the depth of the piston through the spark plug holes and compare when they peak in the cylinder.
  5. jev.
    jev. over there
    I think I bid on that bike. I believe you will find no bent rod, but something else caused it to lose power. I have a feeling you will come out ok on the deal when all is said and done. Just speculation of course.
  6. Lint
    Lint Member
    Simi Valley, Ca.
    That avatar tho!
  7. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Thanks, Lint. I appreciate that you noticed my new avatar ...
  8. Diving Pete
    Sorry I know a reply was given but must have missed it due to avatars....
  9. squirrelman
    let us know what you find. bent rod is unlikely unless it dropped a valve...........but in that case the engine would lock up.
  10. sfdownhill
    Vista, CA
    I've been a bit slow to replay, what with all the avatar action. I'll read the service manual for electrical troubleshooting procedures, start into the compression check, and post results.
  11. NormK
    NormK New Member
    I wouldn't be worrying about electrical troubleshooting till you have proven there is nothing wrong structurally with the motor. Once you have established the motor rotates freely, valve clearances are correct, nothing is amiss with the cams then you can think about cranking it over with the starter motor
  12. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Someone could have hydraulic the motor and bent a rod. Carb drains, fills cylinder and it comes up on the compression stroke. Somethings gotta give...............
    Just use a dial indicator or a set of calipers that read .001 or better at tdc in each set. They should come in a couple of thou to each other (2/4) (1/3)
  13. NormK
    NormK New Member
    Was driving on the freeway and it lost power so unlikely to have hydrauliced the engine
  14. NorcalBoy
    No carbs on '02....could possibly have jumped timing due to worn out cam chain and tensioners, etc. If this is the case, attempts to start it multiple times after the event has destroyed the entire top end.
    Could be as simple as a failed fuel pump.....
  15. sfdownhill
    Vista, CA
    I posted this reply before, but as far as I can tell, it's not showing up on the thread [It seems the only option to replay is to use "quick reply"]:
    Oil filter element is clean - no evidence of foreign material. Engine turns over by hand [14mm socket wrench through the timing hole] and generates good compression on all four compression strokes.
    Question - can anyone confirm that the #4 cylinder is the rear left on my 2002 gen 6? The picture in my service manual really looks like it's rear left, but #4 could be front right...
    More to follow after I drop a little oil down the plug holes, turn it over a few times to clear the oil, then do a compression check. Will the preventative oil down the plug well mess up the compression test readings?
  16. Allyance
    Allyance Insider
    East Bay, California
    It should improve them!
  17. Lint
    Lint Member
    Simi Valley, Ca.
    #4 is front right.
  18. Knight
    Knight New Member
    USA
    Did you have problems quoting? Try clearing your browser cache and restarting the browser.
  19. GreyVF750F
    GreyVF750F Member
    Plug, plug wire, coil, ignition box, fuel pump, fuel pressure regulator, injector are just a few things come to mind. Seeing it lost power when running. Who was the dumbass mechanic? Forget the rod. Didn't see it was running when problem happened. Make sure you have a constant full 12v, without it the ecu doesn't work right.
  20. sfdownhill
    Vista, CA
    I like the sequence "plug, plug wire, coil, ignition box,fuel pump, fuel pressure regulator, injector. ThanksGreyVF750F.
    Plugs out. Engine turns from the timing hole with socket wrench - it's tight for half a turn then loosens up, I presume the tightness is the four pistons going up, looseness is when they go down.
    Existing plugs are NGK Iridium, all look practically new except #4 is blackened. No buildup, but the other three plugs have no discoloration.
    Drain plug on and torqued, new oil filter on, 3.1 liters of new oil in. 1/4 ounce of oil down each plug hole.*Turned engine through 8 revolutions.
    Ready to do compression test.
