Changing the coolant or adding
Discussion in 'New Riders' started by crector15, Aug 2, 2015.
  1. crector15
    crector15 New Member
    My coolant level is low on the reservoir. How do you know when to change it? I have no idea when it was done last. Also is Honda 50/50 coolant a good replacement?
    Sent from my SCH-I605 using Tapatalk
  2. sunofwolf
    sunofwolf New Member
    dexcool gm 50/50 is the lowest cost best
  3. OOTV
    OOTV Insider
    Whenever in doubt about the age of engine fluids, it's always best to just flush and fill IMO. I went with Engine Ice for my coolant but Honda 50/50 should be fine, just stay away from products that have silicate inhibitors. The Honda Service Manual calls for Ethylene Glycol antifreeze containing corrosion protection prohibitors.
  4. squirrelman
    Be sure to give your coolant level a check UNDER THE RADIATOR CAP when engine is cool, and top up there also if necessary. :courage:
