Clutch question
Discussion in '3rd & 4th Generation 1990-1997' started by jorgescar69, Aug 28, 2015.
  1. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    So I find myself in need of a new clutch for my bike. But man, I cant find one thst says it is good with synthetic oil.
  2. Allyance
    Allyance Insider
    East Bay, California
    You won't, lubrication properties of synthetic and dinosaur oil are the same, it is what NOT added to synthetics and what they DO NOT contain that make them better. No friction modifiers, no variable viscosity polymers to break down and no unwanted metals.
    From Amsoil:That tradition of innovation and technological advancement carries on with AMSOIL Synthetic Motorcycle Oil. It is engineered to withstand the devastating effects of extreme heat. It features exceptional high-temperature film strength for maximum wear protection and delivers excellent wet-clutch performance and transmission protection.
  3. jorgescar69
    So it looks like I should drain once more n refill with some real "motorcycle oil" then.
    cuz it did not start to slip till after I used Mobil 1 25w50.
  4. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Huh, that's surprising ... I used to use Mobil 1 synthetic without issue.
    I recently switched to Shell Advanced Ultra RT4 (motorcycle specific) because I found a supplier with it at a very good consistent price.
    Did you change anything else recently? You could try changing the oil, cheaper than a set of new clutch plates I think, but ... ??
    Is the 3rd gen hydraulic clutch? If so, check your fluid level in the master cylinder, check the color, and bleed the line.
  5. Allyance
    Allyance Insider
    Have been running Amsoil 10W-30 (Per Honda Spec!) for last two years in my 2003, then 2014 and my 83 VF750. It is a pure synthetic MOTORCYCLE oil. No friction modifiers. Absolutely no problems. Was the Mobil 1 you used specifically made for motorcycles? Why deviate from specs?
  6. jorgescar69
    Cuz im gangsta like that.... yo!
  7. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Lol!
    Thug life!!
