Conrod bearing purchase source
Discussion in '1st & 2nd Generation 1983-1989' started by Pablo_el, Jun 9, 2018.
  1. Pablo_el
    Pablo_el New Member
    Poland
    Poland
    I need to purchase conrod bearings as my bikes oli pressure drops drastically after it heats up :(
    Only source I was able to find is www.cmsnl.com but I do not see them having all the sizes.
    Maybe someone knows where to purchase them. Any tips appreciated.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Are you sure it's the conrod bearings and not the oil pump itself?
  3. Pablo_el
    Pablo_el New Member
    Poland
    Poland
    I have also found big chunks of gold metal flakes in the oil pan, not good :( That is the materials these bearings are made of.
  4. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Yeah, that doesn't sound good.
  5. squirrelman
    how many miles on the bike ??
    you need to check for engine case stampings that tell the bearing color codes for that engine--if you have them. if not you'll need to meaSure the crank to find which color bearings you need.
    sadly, i doubt any are available, and it may be time to retire the bike to pasture.
  6. Pablo_el
    Pablo_el New Member
    Poland
    Poland
  7. squirrelman
    trying to resurrect a worn out engine may be more expensive than finding another bike. lots of parts would need replacing, most NLA.
    IF your conrod bearings are shot, most likely main bearings are too and you'd want a new oil pump as well.
    any cam pitting problems ?
  8. Pablo_el
    Pablo_el New Member
    Poland
    Poland
    That is what I thought aswell. One cam is pited, not too bad though. Timing chain is gone aswell. I have to many projects so for now this is on hold. I will get back to this in the winter
    I have F2 engine laying around and I will build it up. It has perfect cams and seems to be pretty complete, seized bottom end aswell but lots of improvements over the old one. And I saw some parts on the web for F2 :)
