Coolant leak under water pump on 2002 vfr
Discussion in 'Mechanics Garage' started by thephatboi, Dec 9, 2016.
  1. thephatboi
    thephatboi New Member
    I see others have had this problem but I could not find if it was truly the water pump needing to be replaced or just seals;
    I have a 2002 VFR and have a slight coolant drip at the bottom of my water pump, bike always has run cool so the pump is working, can I fix this by replacing all the seals/O-rings or do i need a new water pump period? Thanks for any info:)
  2. OOTV
    OOTV Insider
    I replied on the other thread you posted in but long story short, I replaced the water pump because the individual gasket was on back order and I didn't want to wait for it to come in.
  3. thephatboi
    But if I was able to get all the seals/gaskets I could fix this without replacing the whole pump? Or is there any internal seals in the pump that I can't replace without replacing the whole pump? Thanks a lot!
  4. thephatboi
    My milage on the odometer is about 20k btw, probably original wp I'd guess.
  5. RDMCD
    RDMCD New Member
    London Ontaorio
    Make sure its not just trickling from higher up. The hose clamps should all be tightened a little every few years.
  6. OOTV
    OOTV Insider
    Based on the parts fiche, looks like a simple gasket is all that seals the two halves of the pump.
  7. thephatboi
    Cool, wondering if I can get that middle gasket from Honda, anybody replaced that gasket before? I've never taken out a water pump from a VFR so don't know how the pump is put together…:)
  8. squirrelman
    Based upon my '86/'87 VFR experience, i'd say the pumps are NOT rebuildable, but i hope i'm wrong. :disturbed: Seems the impeller can't be pressed off its shaft to access the seals.
  9. Droldaerd
    Droldaerd New Member
    For my 4th gen, there's an O ring that goes around the male end of the pump, and a gasket, rubber, between the pump and propeller cover. Both were readily available for me on bikebandit.com for about 14$
  10. thephatboi
    Cool thanks guys, mine is a 2002, so 6th gen? wonder if that is different from the 4th gem, pump...
