Destroyed my Swingarm, take my advice.
Discussion in '1st & 2nd Generation 1983-1989' started by JasonWW, May 19, 2013.
  1. JasonWW
    JasonWW New Member
    Hou. TX
    The moderators here are a joke. They don't do anything nor do they ever respond to any emails. Without good moderators this forum is going down the tubes. Keep reading and you will see the evidence.
  2. TheBeeDeeGee
    TheBeeDeeGee New Member
    Houston
    Geeeeeeez! Lucky nothing catastrophic happened to cause a wreck.
  3. Scubalong
    :hss: you are a lucky man. The man above is watching over you.......
    Go buy loto if I were you.........Wow that is in sane :crazy:
  4. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    A guess would be you actually over-torqued the studs. Possibly damaging the threads on the hardware or the hub. Allowing the studs to "walk out" over time.
    Definitely replace all the hardware. Take a good look at the sprocket & hub for damage. If there are deep impressions on the sprocket from the nuts consider replacing that as well.
    You are very lucky.
  5. slowbird
    slowbird Member
    Toronto, Ontario.
    Wow! That is some Awesome carnage right there.
    Having said that I'm super sorry about the damage to your bike and am very glad you are ok.
    Quite unbelieveable.
  6. JasonWW
    JasonWW New Member
    Hou. TX
  7. JasonWW
    JasonWW New Member
    Hou. TX
  8. lshark
    lshark New Member
    NY
    buy a torque wrench !!!
  9. JasonWW
    JasonWW New Member
    Hou. TX
  10. WetSpot
    WetSpot New Member
    Ferntree Gully, Melbourne
    So you can properly torque bolts/nuts then properly retorque them every so often - a 3lb sledgy is a stud fucker, NOT a torque adjuster...
  11. JasonWW
    JasonWW New Member
    Hou. TX
  12. WetSpot
    WetSpot New Member
    You are the one who stated you used a 3lb sledgy, don't insult me by stating how insulted you are are when you clearly have no fucking idea how to torque a bolt - "I tightened the sprocket bolts with a 19mm wrench and whacked the end a few times with my 3lb sledge to get them nice and tight (approximetly the same force required to loosen them). " Anyone with an ounce of mechanical aptitude knows the force required to undo a bolt is NOT necessarily the torque required to do them up...
    And yes, I think you over torqued them, the same issues are common place and well documented on car/truck wheel studs which are over torqued...
  13. lshark
    lshark New Member
    NY
    "I did an inspection on the one stud that came out the most and did the damage. The threads in the hub are in perfect shape. I even cleaned the aluminum out of the threads on the stud. All fine now."
    hint #2...cleaned the aluminum out of the threads !!!!!! ---- 3 lb sledge
  14. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    That tells the whole story of what you did and the type of mechanic you are. A 3lb sledge as a torque wrench for tightening studs in ALUMINUM.!? Yep close enough. The only question remains "for who"? Sorry but with what happened I can't believe it couldn't be felt or heard. Your lucky, real lucky..................
  15. duccmann
    Shit Jason...chill.....if ya dont want GOOD AND THE RIGHT advice dont fucking ask
  16. Badbilly
    How bout using a 2lb torque wrench or two 1lb torque wrenches or a framing hammer?
    When a dude states he can apply a recommended 70-80 foot pounds of torque with a sledge hammer and then suddenly becomes a master mechanic, the BS meters peg out..
  17. tyarosevich
    tyarosevich New Member
    Seattle, WA
    There's a lesson here: hitting a wrench with a sledge is not how you should tighten anything on a vehicle.
  18. duccmann
    yeah I am very experienced mechanic but I don't have a freakin torque wrench but I got a sledgehammer... that will do... really dude
  19. OOTV
    OOTV Insider
    I think you answered your own question and I'm with Duccmann, you have to expect advise or remarks that you may or may not agree with.
    As far as working on stuff myself, if the bolt or nut is for something trivial, I'll use my experience and tighten to what feels right, but if it's something like a brake caliper, axle nut, or other important fastener, I grab the torque wrench. Yes, it may be a $50 part, but it could have been your life or someone else's if this were to have gone to a more catastrophic level. I will say that I have not seen any FSM tell me to take a 3lb. sledge and give it a "close enough" whack!
  20. ridervfr
    Belgium
    I like using an Eastwing framing hammer for torques above 80 foot pounds. What about Newton-meters, does that mean you eat a few fig-newtons then get a BMFH and beat you shite to death? Was trying to quote BB but couldnt, gawd for-give meeEEE :pope2:
    I trust my feel with a t-handle and use electric impact shit to tighten/take off smaller stuff. I also trust my air-impact stuff with the appropriate square (3/8 - 1/2. sorry no 3/4 stuff cause I dont work on trains.) :lol:
