fan stopped working
Discussion in '5th Generation 1998-2001' started by loosenoose, Dec 7, 2017.
  1. loosenoose
    loosenoose New Member
    let me first say that i'm not good at electrical problems, so pretend like you are explaining this to a small child, lol
    i replaced the fan switch on the left radiator after i noticed my fan was no longer kicking on. that didnt fix my problem. any ideas of what to check next?
  2. Samuel
    Samuel Member
    Los Angeles County
    Fuse maybe?
  3. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    Is the actual fan working?
    Pull the wire from the switch while ignition is on and ground it.
    Fan should run.
  4. Terry Smith
    New Zealand
    The power feed to the fan motor is always "live"; the thermoswitch just completes the circuit to ground. You should always see battery voltage on the supply line, hence as Oz says, if you jumper the fan switch wire to ground you should have a running fan.
    I have had an occasion where a small rock had lodged between the fan blade and shroud and stopped it from spinning.
    OZ VFR likes this.
  5. OZ VFR
    OZ VFR Member
    You always have a better way of describing things Terry.
  6. loosenoose
    fuses are all good.
    havent tried that yet, but i should have some time to check into it this weekend
    i can spin the blades with my finger. the fan has no problem actually spinning. i'll try bypassing the switch this weekend some time. i hope i can get it working again. also, i shoulda rode to work today! the bike woulda been just fine, lol. i live in the houston area, and i got about 2 inches of snow last night!!!!!! wtf! that's the most snow i've ever seen here. the only thing that compares is the big freeze of 94, but that was all ice
  7. squirrelman
    remember that the fan motor must be grounded, usually a green wire between fan motor and its frame, which grounds to chassis. power to fan comes from a 2-pin connector, one+ and one to ground.
  8. OZ VFR
    OZ VFR Member
    The 5G fan is switched on by the ground wire via the radiator.
    12V+ to fan is always on if ignition is on.
    That's why if you remove wire from temp switch and touch the frame, fan will run if ignition is on.
  9. squirrelman
    yes, but only if wiring to fan is connected. :band::band:
  10. OZ VFR
    OZ VFR Member
    That is true.
    I was just refering to the ground wire from fan, it doesn't go to the frame, it goes directly to the temp switch.
  11. loosenoose
    i grounded the fan switch line to the frame and the fan did not turn on
  12. Darth Vader
    Darth Vader New Member
    melton mowbray
    So that means the fan isn't getting any power. Can only be broken wire, corroded connection or fuse. Don't ya just hate electrics.
  13. loosenoose
    Yes, I do hate electrics!! :p
    I found out it's a bad ground on the side of the main wire harness. If I move the green wire a little, the fan runs. Would a drop of solder into the connector fix it? I tried zip tying, or duct taping in just the right way, but neither worked well.
    I'm also in the infancy of a streetfighter project, and took everything apart from the dash and now the bike won't start, even with all connections made. Wtf, Vfr.
    The bike will crank, but the fuel pump doesn't prime
  14. Diving Pete
    Always cure bad earths...
    Run another line to earth if you want to - its usually easier to make a new earth than to trouble shoot the old one..
    loosenoose likes this.
