Fork Swap
Discussion in '5th Generation 1998-2001' started by VFR4EVA, Oct 30, 2013.
  1. VFR4EVA
    VFR4EVA New Member
    Hey all,
    Can anybody confirm if you are abel to swap out 5th Gen forks / Triples with 6th Gen ones?
    Cheers,
    V.
  2. mello dude
    Romania
    ^^^^ Yes they will swap. You will need the 6th gen clip ons too.
  3. derdummkopf67
    derdummkopf67 New Member
    Los Angeles
    I believe you will need a sixth gen triple tree too. I bought a sixth gen top triple and it was larger than fifth gen.
  4. OOTV
    OOTV Insider
    The 5 Gen uses 41mm tubes, and the 6 Gen uses 43mm tubes. At least on the later versions 6 Gen, something tells me that the early 6 Gens had 41mm initially, but I could be mistaken. I just know that my '01 has 41mm and my '09 has 43mm. Internally they are basically the same, so if you are looking for better damping performance, different valving and/or springs would be needed.
