Instrument Bulb Replacement Hunt
Discussion in '5th Generation 1998-2001' started by Skifreak, Feb 10, 2013.
  1. Skifreak
    Skifreak New Member
    Washington State
    Ok, so the pictures of splitfin's gauges inspired me. My new LED's are on their way in the mail, so now my gauge lighting (even idiot lights like neutral, high beam, turn signals, etc...) will be all LEDs. Before and after pics to come.
    On a side note, when the VFR headlights are on low beam, are both headlights on low beam? Currently, only my right beam (as seen from the rider's point of view) lights up on low beam. I assumed it was supposed to be this way, like the old GSX-Rs used to be.
  2. Scubalong
    They both should be on....one side might have a burn out bulb
    All four should be on when you switch to hi beam.
  3. Skifreak
    Skifreak New Member
    Washington State
    Ok. so the low beam on the left bulb is burnt out. Replacement time. Do you have HID headlights? Looking at the HID kit sold by Wiremybike.com which is made by DDMwith the built in delay. Is is worth the $155?
    I also noticed I am jacking my own thead. sorry.
  4. Scubalong
    Hell that is way too much :crazy:
    DDM is two bock from me. They have special for $35 a pair
  5. silverbullet132
    silverbullet132 New Member
    The kit he mentioned is a dual bi xenon. Has the time voltage relay to turn on hid1 and time relay to turn on hid2. Ddm does not even offer that lol
    Sent from my SH-02E using Tapatalk 2
  6. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    In order to change the bulbs on the instrument cluster, does the fairing have to come off? I think I got a bulb or two burned out.
  7. silverbullet132
    Check out this thread there is a whole bunch of info on the topic within:
    5th gen blue gauges - Modifications - VFR Discussion
    It is where I found this list of bulbs needed to do the 5th gen:
    That has 1 spare bulb of each included. Not a good idea to do the FI light, might make it flash too fast making any code impossible to read.
  8. Scubalong
    Did not know that was a 5th Gen.........Never mind
  9. Skifreak
    Skifreak New Member
    Washington State
    Sorry, I forgot to mention I have a 5th gen. Sounds like I have a headlight bulb out on low beam only. Now once my dash is done (bulbs should be here tomorrow), I have to decide on HID lighting.
    Is HID worth it? I would likely get the dual bi-xenon with the time delay. I should probably have started another thread for the HID topic.
  10. silverbullet132
    Yeah it is worth it. I am ordering the same kit soon because I so not want to risk breaking my headlight to install projectors :)
  11. Skifreak
    Skifreak New Member
    Washington State
    Before LEDs
  12. Skifreak
    Skifreak New Member
    Washington State
    Replaced just left hand side bulb with a green LED for side by side comparison.
    Dash with all green LEDs installed. Big difference, especially on the LCD screen. Also replaced turn signal indicators and idiot lights with appropriate color LEDs, but not the FI light so it can blink codes properly.
    Probably cost only $25 total which is worth it to have brighter dash not have to mess with it again. Ever.
  13. silverbullet132
    Which exact LEDs did you use?
  14. Skifreak
    Skifreak New Member
    Washington State
  15. silverbullet132
    Finally did this mod, but not to the turn signals or other indicator lights. Before I swapped all the LEDs to solid blue, I tried these rainbow ones I found :):
    [video=youtube;K5wqJ2QtnbA]http://www.youtube.com/watch?v=K5wqJ2QtnbA[/video]
  16. ridervfr
    Belgium
    Thats CRAZY Man :hippie:
    Do they have those pot bars up in the great north :canada: ? I was seeing trails and all kinds of psychodelic stuff on your youtube video. Good stuff
  17. silverbullet132
    Haha nah :p
  18. Skifreak
    Skifreak New Member
    Washington State
    Not distracting at all.
  19. silverbullet132
    Which is why it is solid blue now.
  20. Make56
    Make56 New Member
    Finland
    Kirkkonummi
    Last winter I replaced all bulbs in my 3rd gen dash to led ones. I used red leds bulbs with leds pointing also sideways for the gauge light and for the indicators white leds with the lens. I think the watts were the same. After reassembling things I found out that green indicators (turn and neutral) look more blue than green, so I have now replaced those with green leds.
