Just bought a 1991 vfr750 for £570, have a look...
Discussion in 'Introductions' started by Y282, May 25, 2014.
  1. ridervfr
    Belgium
    Clutch switch
  2. ridervfr
    Belgium
    neutral switch is bad? its a one pin connector like the thermastat, believe its a pretty simple switch.
  3. ridervfr
    Belgium
    like the grey wheels!
  4. Outboard John
    Outboard John New Member
    Escondido, Ca.
    Plus 1 on the wheels, the whole package looks really sharp! Any pictures (before and after) of your plastic weld repairs?
    John
  5. Scubalong
    Belate :welcome: to the zoo from across the pond :wave:
    Nice Score on the bike :thumb:
  6. Y282
    Y282 New Member
    Thx for the comments :)
    Just got back from series of road tests, it's really comfy and a bit quicker than i thought it would be. Got to resist the urge to do any more cleaning and tidying now as i need to ride it for a couple of weeks in all weathers.
    Cheers for the heads up on the switch, i'll give it a look.
  7. Y282
    Y282 New Member
    Mini update, ive since had to replace rr and stator, build new heavy duty stator wire loom, build own vfrness an fit new battery. It now starts, runs charges and stays cooler on rr.
    Also ditched rear pegs and centre stand and cut rear guard down...
  8. Scubalong
    Nooooooooice bike mate :thumb:
  9. ridervfr
    Belgium
    I got caught in the rain today with mine, I dried oot enough were I did'nt have to change my clothes. I ordered new oem fork seals as I got a leak on one leg. Anyway, with the new grips on the bike, it rides pretty much like my other one does. Interesting, upon disassmebly when I installed the fork springs, the bike was missing both spacers, had a funny spring with close windings towards the bottome. Maybe a progressive spring? But to not have a spacer? Thats weird. Front end is nice with new springs/spacers and 7 weight oil. Now I have to do the "drill" over because of the leaking seal. :mech:
    Cheers
  10. Y282
    Y282 New Member
    I thought they all had progressive springs? Mine certainly had when i pulled them apart.i've probly got a pic of the internals somewhere from the build if it helps.
  11. ridervfr
    Belgium
    I got my originals from the 91 and compared them, (saved from 20 years ago) they were a whisper longer. Front end feels nice now and can work on removing the last bit of untouched strip of my tyres. New bike is a 93, basically same chit. Played with the fuel mixture screws, tyring 2 turns oot instead of 2.5. Easy enough to return or change.
  12. Y282
    Y282 New Member
    You guys get the weather to use the whole tyre! It pisses down here for 3/4 of the year.
  13. MPH Racing
    MPH Racing New Member
    Calgary Alberta Canada
  14. Y282
    Y282 New Member
    I pulled the two wires from the clutch lever switch and blanked them off. Works fine without it.
  15. Y282
    Y282 New Member
    So i've got it looking roughly how i want it now. Thinking about pulling front legs through a bit for stance and handling but not sure how the handling will take it. It has a bit of a problem with leaning too far on the stand, the angle is VERY far over.
  16. ridervfr
    Belgium
    will measure how much fork tube protrudes up through the top. I have a mental brain fart right now as I am on my second bottle of wine. :drinkers:
  17. Y282
    Y282 New Member
    Did mine earlier. 10mm made sod all difference. Did 1" and it sits and rides much better now. image.jpg
  18. Y282
    Y282 New Member
    Mini update, won a standard screen on ebay for fifteen quid, prefer it to the black double bubble one...
  19. ridervfr
    Belgium
    Damn, thats a good screen! I was trying to get the last oem one for a gen3 bike a year or so ago, it came and was damaged. I ended up getting a Skidmarx screen. Good quality and optics, my latest project a 93 has a hopelessly disgusting screen. Withoot Ebay, I would have been up a creek withoot a paddle. I am done with parts as it runs good, I would run top end with yah oot in the "everglades" if you were'nt on the other side of the pond :pound: Cheers
  20. ridervfr
    Belgium
    I got a bunch of those "aqua-trax" black bird ala cbr1100xx large 6mm allen head bolts that are stainless steel. I ended up putting them on this bike, I have some nasty corrosion issues like a cat or a rat was pissing on my swing arm and near the frame. Not gas stains, so its never gona be a beauty queen :sad: but its a good runner, makes me laugh how you can find a 20+ year old motorycle with low miles :thumbsup:
