Looking for vf500 spark plug wires and petcock
Discussion in '1st & 2nd Generation 1983-1989' started by VfMattf, Aug 27, 2009.
  1. VfMattf
    VfMattf New Member
    Twin Cities, MN
    I am new here. I have been learning a lot reading up on VFRs on this forum and have pretty much fallen in love with them.
    I hate sounding needy but my bike is old and in need of parts and I'm having trouble locating some. As it says in the title I am looking for spark plug wires for an 85 vf500 (specifically the left rear and front right) and a petcock.
    -Matt
  2. volks6000
    volks6000 New Member
    Jacksonville , Florida
    petcock off e-bay, wires you could make your own.
  3. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    whoa your name is matt to small world huh? lol welcome to the forum matt eaby and craigslist will become your friend :thumbsup:
  4. squirrelman
    HONDA.original.plug.wires.are.the.best.quality.u.can.find.and.seldom.fail-----even.on.25year.old.bikes
    most.replacement.wires.are.not.as.good.......and.don't.fix.your.problem
    you.can.buy.solid-wirecore.plug.wire.cut.to.length.from.bulk.role.at.a.good.autoparts.store
  5. VfMattf
    VfMattf New Member
    Twin Cities, MN
    I wouldn't have asked about the petcock cause I saw one on ebay last week (there aren't any at the moment) but I really want one as soon as possible cause I'm itching to ride. ;)
  6. volks6000
  7. VfMattf
    VfMattf New Member
    Twin Cities, MN
    It's cracked and thus leaks.:frown:
    I had never used the reserve before and one day I needed to and so switched it over and went and filled up and turned it back to on. I then went home and parked the bike and the next day there was a large puddle of gas under the bike and the side of the engine was covered in gas. I think the crack was probably there prior to this and actually turning it several times aggravated it causing it to leak.
  8. volks6000
    leak from the front?? crack ?? what part
  9. VfMattf
    VfMattf New Member
    Twin Cities, MN
    The crack is along the part that mounts to the tank. I'm kind of new to bikes so I don't know all the terms for everything. Thank you very much for your help so far.
  10. volks6000
    did you try jb weld to see if you can seal it. get it from any auto parts store.
    this is mine that i got off e-bay
  11. slowbird
    slowbird Member
    Toronto, Ontario.
    Is that yellow Condom supposed to be on the Petcock?
    Mine doesnt have one. :confused:
  12. volks6000
    that's the tank filter,when in the tank it's pointing streght up.
  13. VfMattf
    VfMattf New Member
    Twin Cities, MN
    I have a friend that has a petcock that doesn't work in the on position. But it has no leaks. I'm probably just going to take it and use it for now on reserve. Anyone know what could be causing the on position to be blocked or to not allow fuel to flow?
  14. squirrelman
    take.it.off.and.inspect.it,Matt.........probably.some.debris
  15. TRX250R
    TRX250R New Member
    R.I.
    I have a 86 parts bike in the back yard. The plug wires are used but i'd part w/ them.
