Power Commander query from UK noob.
Discussion in 'Mechanics Garage' started by adeyren, Sep 9, 2014.
  1. adeyren
    adeyren New Member
    Worcester UK
    Hi guys
    Just got my 2001 VFR 800 3 months ago after a break from bikes for 30 yrs!!! ABSOLUTELY love it. Last bike was a Rd 400 Yamaha. Big difference!
    Done just over 4000 miles in last 3 months including a 1800 mile trip round Southern Ireland.
    Thinking of buying a Power Commander (http://www.ebay.co.uk/itm/351163540233?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT).
    Can anybody tell me what difference it makes to the bike and any tips on setting up etc etc.
    Thanks all
  2. Gator
    Gator Insider
    Don't know about the PC3 in the ad but I installed a PCV and loaded a map from Power Commander. Bike is much more smooth through out the rpm range especially in the low rpm area where it could be a little snatchy. Low rpm through mid high torque seems more linear and pulls harder. High rpms seem no different. Vetec transition is much better.
  3. Mousejockey
    Mousejockey New Member
    Manchester UK
    Hi adeyren,
    I also got back into biking this march after 10 years out.
    I purchased a VFR800 Vtec A6 and although a good bike I found it a little jerky in low revs so looked aroud this forum for answers.
    I finally bought a second hand PCIII off eBay for a bargain £210
    I installed it it about 10 mins including the O2 sensor bypass plugs and uploaded the standard map to it.
    I have to say it sorted the fueling out straight away...
    The whole lower rev range was smoother and the Vtec engagement smoother.
    I was so pleased I even went and got it dyno'd @ Jordan bikes in Leeds
    and that made everything even better !!!
    My fuel economy increased as well as gaining 7bhp and 3ftlbs torque.
    For a bike of now 30,000 its figures are within 2bhp and 1ftlbs of a new bike.
    Including the ''ACCEL PUMP'' feature which gives you an extra bit of fuel injection when you CRACK the throttle open it makes for a lively ride :)
    I have to say that I am very pleased with it and I have since replace the pogostick rear shock with a custom weight matched Maxton shock
    and sorted the front forks out with linear weight matched springs and re-valve.
    But that's beside the point.
    Buy a PCIII you wont be disappointed :)
    Hope that helps
  4. adeyren
    adeyren New Member
    Worcester UK
    Thanks for that. Am interested in the Maxton shock and front fork work. Got any links for info etc
  5. Mousejockey
    Manchester UK
