Quality rectifier/regulator?
Discussion in '5th Generation 1998-2001' started by ksoholm, Feb 8, 2017.
  1. ksoholm
    ksoholm New Member
    All,
    Who makes quality units for preventive upgrade?
    Thanks,
    Kristian
  2. skimad4x4
    France
    French Alps & London
    If you have not spotted it yet it is perhaps worth reading this thread.
    http://vfrworld.com/forums/showthread.php/39277-How-to-fix-common-regulator-Stator-failures
    As for a replacement - you will find loads of aftermarket kit has been tried with varying degrees of sucess. Avoid cheap chinese copies circulating on eBay. The safe bet is to order an OEM Shindengen RR from Jack at http://www.roadstercycle.com/ Loads of people on here have used their RRs and thus far not a single reported failure. If you need help choosing the right kit of with the install just speak to Jack.
    Good luck
    SkiMad
  3. Laker
    Laker New Member
    Ontario
    Hi Kristian. As my friend Skimad says, check roadstercycle.com. The FH020AA Supermosfet Kit is a perfect fit for the 5-Gen and a easy install. It runs much cooler then OEM. As we always say, cut out the plastic connector and solder the yellow wires, install a volt meter and you should be good to go for a long time. Good Luck!
  4. ksoholm
    ksoholm New Member
    Thanks, gents-Roadster it is.
    Kristian
  5. RVFR
    Awe, beat me to it.. what they said. ;)
  6. bitterpil
    bitterpil New Member
    Northern Virginia
  7. BTF/PTM
    BTF/PTM New Member
    Germany
    I've got a RicksElectric unit that I got thru WireMyBike, so far it's been great.
