Replacement fork tubes / stanchions?
Discussion in '5th Generation 1998-2001' started by Pandemonium, Dec 23, 2017.
  1. Pandemonium
    Pandemonium New Member
    Santa Cruz, CA, USA
    Anyone have a recommendation for replacement fork stanchions?
    I am upgrading my suspension (DMr cartridges in front, DMr shock in the rear) and there are some pits in the fork stanchions/tubes. I'm trying to figure out if it's worth replacing or just sanding & polishing.
    Thanks!
  2. OOTV
    OOTV Member
    I have some 41mm tubes from a set of VTR1000 forks. Actually have the sliders too, I took the internals for my 5 Gen rebuild. PM me if you’re interested. They’re just taking up,space in my garage.
  3. Pandemonium
    Santa Cruz, CA, USA
    Thanks! If I'm going to replace mine, I would like a brand new set. I appreciate the help, though.
  4. Pandemonium
    Santa Cruz, CA, USA
    Some Googling has led me to Tarozzi fork tubes:
    http://www.fastfromthepast.com/fork-tubes/fork-tubes-chrome
    http://www.fastfromthepast.com/05-0395
    $175/each.
    Anyone have experience with them? They seems to make replacement fork tubes for just about every bike. Nobody has them in stock for a 5th Gen, though, so it'd be a special order and would take 5-6 weeks.
    For that cost and order time I'm tempted to just have my mechanic sand and polish my stock fork tubes and hope that's good enough to not kill another set of seals for a few years. I'd love any thoughts from anyone with experience here.
  5. OOTV
    OOTV Member
    No worries. If you change your mind, I'm only a PM away. Cheers and good luck with your refresh.
  6. wstark54
    wstark54 New Member
    Try http://franksforks.com, used them over the years and always great product.
    ducnut likes this.
  7. Pandemonium
    Santa Cruz, CA, USA
    Will check them out. Thanks!
  8. Pandemonium
    Santa Cruz, CA, USA
    Update: six months later and my leaky fork seal returned. Apparently we didn't completely remove whatever burr caused the leaks when we polished them. Now I get to tear it all back apart. :-(
    I'm going to do new tubes this time since I don't want to mess with it again for a long time.
    I have a quote request in with Frank's Forks.
    I also found that a Polish suspension company called Tecrol used to make replacement forks for 5th Gens. There's precisely one left here:
    https://www.ebay.com/itm/Front-fork-tube-Honda-VFR-800-FI-1998-2001-/192331910155
    Too bad I want to replace the pair.
    Let me know if I missed any options, or if anyone has experience with any of them. Unless there's a reason not to, I'll probably go with whoever is cheaper between Frank's and Tarozzi.
