Replacing Fork Seals, 87 VF700F2
Discussion in 'Mechanics Garage' started by MiddleTBabb, Mar 14, 2010.
  1. MiddleTBabb
    MiddleTBabb New Member
    Murfreesboro, TN
    They are leaking badly (onto the front brakes!) and I need to replace. I figured I would save some dough and do it myself... but the bike does not have a center stand, and I need to buy a stand for this job. or... do i? and if i do, any suggestions?
    NO stand no problem
    YOU need a sturdy wall or shelves or a tree to lean the bike very slightly to the right side and a strap-around the frame to secure it, then a sissors jack, some blocks of wood.........
    First use blocks in front and back of front wheel to prevent possible movement. Next place jack and wood under the mounting points on frame where centerstand would bolt. Lift rear wheel about 3-4". Then place supports under center of engine as high as possible. Next, let the jack down slightly, and THE FRONT END WILL LIFT !! You're UP at both ends !!
    Without stands, i've use this method often with no problems.
    Best to do heavy torquing ( front or rear wheel axle ) while bike is still on sidestand.
  3. MiddleTBabb
    Murfreesboro, TN
    wow. awesome. thank you much!
  4. Comicus
    Comicus New Member
    East Nashville
    Then after you replace your fork seals we can get started on your new baby. air box mod, o2 eliminators, new exhaust, power commander, new sprockets, gut those cats, ect... :cheersaf:
  5. MiddleTBabb
    Murfreesboro, TN
    So I have the bike lifted now. Having trouble with the main front axle bolt...and no air tools. Any advice?
  6. squirrelman
    Have you loosened the 2 pinch bolts on the bottom of right fork ??
  7. MiddleTBabb
    Murfreesboro, TN
    HAHA yes. to explain me manual told me to. gotem off now, now to order the new parts. thanks for the help
  8. squirrelman
    Babbs......forgot to mention that it's best to loosen fork caps (1/2 turn) while they're still on the bike
  9. crustyrider
    crustyrider New Member
    North Country, New York
    don't think an 87 would need all of those mods......:crazy:
  10. MiddleTBabb
    Murfreesboro, TN
    ahh! got em off! just ordered seal kits. thank you much for the help. this is a newbie mechanic who just wants to save money and hopefully get his old bike in order to sell to help pay off the new one! By the way crusty that was my buddy trying to talk me into all those mods on my 07 VFR800....but i am resisting! she is a beaut' how she is!
  11. Comicus
    Comicus New Member
    East Nashville
    HAHAHA! he called you babbs...That's ur name from now on!!!
