Stainless steel replacement brake pistons
Discussion in '8th Generation 2014-Present' started by Thumbs, Apr 11, 2017.
  1. Thumbs
    Thumbs Member
    Bath(ish)
    The front brake Pistons on the 8th gen have already rotted on at least 2 motorcycles, OEM pistons vary from $200-400 for 8 and they'll rot as well
    A company called Powerhouse in the UK have taken the initiative and made stainless steel replacements, $150 (£120) for 8, so the front is sorted
    As far as the rear goes, they're pretty sure they have them but want clarification of the depth of the pistons
    They're either 31mm or 33mm deep or long
    Does anyone know which it is?
    If they can supply them they'll be about $45 (£38) a pair
    They can also supply all the seals, etc
  2. OOTV
    OOTV Insider
    Looking at the parts fiche, this is what the detail shows. I hope this helps.
  3. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    This is unbelievable that anything on an 8th gen is failing already. Here I was thinking, "finally got rid of that linked crap and fitted radials" and its even more unreliable now lol.
    At the numbers you're talking, I would just slap some brembos on there and be done with it.
  4. Thumbs
    Thumbs Member
    Bath(ish)
    You have luxury of unsalted roads ....
  5. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    True. But are these nonstainless pistons a new thing or has this been an issue on previous vfrs as well?
    Sent from my Nexus 6 using Tapatalk
  6. Lint
    Lint Member
    Simi Valley, Ca.
    I'm by no means super well informed, but I've been on this forum since 2012 and this is the first I've ever read about this. Not on VFRD.
  7. Thumbs
    Thumbs Member
    Bath(ish)
    That's where it's being discussed and resolved, in the 8th Gen forum
    Lint, the degree of salt damage in this country is beyond your comprehension, Lancia made a car, the Beta, after 3 yrs it was junk from rust damage .... imagine dipping your front end into the sea for 2/3rds of December and January
    BTW it's not a Honda part, the Tokico pistons "rot like tin foil"
  8. OOTV
    OOTV Insider
    Funny that you mentioned this. I have been watching some Delboy's Garage videos and this was one I just recently watched. It's about winter brake cleaning, mostly due to your road conditions.
    [video=youtube;iHeEw2t_ETM]http://www.youtube.com/watch?v=iHeEw2t_ETM&index=36&list=PLRS52UHF-MfloqvvJl3IN6aKFlofPmwiX[/video]
  9. fink
    fink Member
    The UK piston problem is the same as the US K&N problem. It's common on most road bikes ridden over the winter months in the uk. Only wat to avoid is to not ride or regularly grease up the pistons ( calliper grease) and avoid pressure washers.
