Torque values???
Discussion in '8th Generation 2014-Present' started by V45mikie, Dec 2, 2017.
  1. V45mikie
    V45mikie New Member
    Ok Gang, any idea on the torque values for the 6mm bolts on the clutch slave cylinder and chain cover. I just did a chain swap and I cant find them in the 8th gen book.
    Also I cant believe I'm asking this question. I've completed a spark plug swap and a oil change and I seem to be experiencing slight rubbing sensation/vibration in the bike that was not there before. Its prevalent around 3500 rpm and up to around 6000 rpm. If I clutch her out of gear at speed and let the engine go to idle it goes away. So I don't think its the chain and sprocket swap. I've checked the exhaust headers so all four plugs are firing and I've put Motul 300V in her so I think lubrication is good.
    Just waffling for some ideas.
  2. Allyance
    Allyance Insider
    East Bay, California
    Here is a chart from my 8th gen manual, hope this helps:
  3. V45mikie
    V45mikie New Member
    OK that's the one I have , they just looked kind of high on some. That's the ones I went with.
  4. fink
    fink Insider
    Nope M6 = 10nm
