Variable air intake solenoid valve
Discussion in 'Mechanics Garage' started by Gman, Nov 30, 2008.
  1. Gman
    Gman New Member
    Montreal
    Hi guys,
    Can anyone explain the function of the Variable air intake solenoid valve ?
    Reading through my service manual and I am curious.
    Same for the Bank angle sensor ?
  2. drewl
    drewl Insider
    Virginia Beach, Va
    I believe the bank angle sensor shuts off the bike if you lean over too far. I could be wrong.
  3. Gman
    Gman New Member
    Montreal
    sounds logical....
  4. NorcalBoy
    The bank angle sensor shuts off the the electrical power in case you are involved in a crash. This is so the fuel pump will stop pumping to reduce the risk of a fire related explosion of the fuel tank.
  5. drewl
    drewl Insider
    Virginia Beach, Va
    That's what I said. Duh.
  6. junktionfet
    junktionfet New Member
    Raleigh, NC
    The variable air intake solenoid valve operates the variable air intake valve in the air filter box. The valve is designed to open at 5500RPM and close again around 5000 RPM. Its purpose is twofold--for one thing it causes a slight reduction in air intake noise at low RPM, but most importantly, it can increase the velocity of air entering the air filter box, giving a very slight boost in low RPM torque.
    A lot of people remove it because they like the extra little snarl it gives the intake.
    The difference in airflow it makes is only a consideration at or near Wide-Open. At light or part throttle there's no way you'd notice if the thing was working or not.
  7. Gman
    Gman New Member
    Montreal
    Thanks for the feedback guys !
    I'll try not to test the bank angle sensor the hard way....
