VF500F Instrument Cluster Problems
Discussion in '1st & 2nd Generation 1983-1989' started by Mind_Surfer, Apr 11, 2017.
  1. Mind_Surfer
    Mind_Surfer New Member
    VA
    First, the trip meter hasn't worked in years, no biggie. Second, the tachometer is jumping quite a bit, but only when winding it up, and bounces after upshifts. I do plan to do a run-up on the rectifier, to rule that out. Any advice? Thank you.
    PS: I should add that the igniters are brand new, tach issues present before and after replacement.
    100% of the time I've seen a jumpy tach on a 500, it has been the battery. Even one that can start the bike.
  3. Mind_Surfer
    VA
    Thank you Captain. I will check that too.
    Sent from my XT1031 using Tapatalk
  4. Mind_Surfer
    VA
    I put a meter on the rectifier, it checks OK as in no voltage spikes when RPM is increased. The battery I am not sure how to check, it is only a couple months old.
    How many volts at the battery at idle and at 4000 rpm or so?
  6. Mind_Surfer
    VA
    The same, 14.89VDC
    Well, shit. I'd start looking at connections for tightness and corrosion. How many miles on bike again?
    Wait... 14.89 at idle?
  8. Mind_Surfer
    VA
    Ya at idle. 37,000 miles
    Problems before and after new battery? Did it go away at all right after the new battery?
  10. Mind_Surfer
    VA
    Captain, the motorcycle was unused for 14 years, I'm sorry I honestly cannot recall. But, the tach has been a jumpin' ever since I put it back in service.
    OK, got it. That high at both idle and revs is odd. You normally should see a drop at idle. And that is an excessively good reading, high 13s to low/mid 14s is considered great. I think you are overcharging and it could be responsible for screwing with the tach and possibly cooking the battery.
    Here's where I would swap a different reg/rect as a test, but I realize most people don't have that option handy. Keep an eye on your battery fluid levels, they may need topping off frequently.
    Oh, and, I have seen MANY times rectifiers that tested as "bad" work perfect and rectifiers that test "good" simply not be the case.
  12. Mind_Surfer
    VA
    Thank you Captain for your time and assistance! I have already been considering the purchase of a new rectifier, sounds as though I should go ahead with that. Will check the fluid levels later tonight. I really appreciate the help.
    You bet! This is what this place is all about. Cheers.
  14. RobVG
    RobVG Member
    Seattle
    Does that apply to a 700?
    You bet. Every time I have seen my tach jump around (has happened on my 500 and a couple 1000s) it has been a bad battery or a bad battery from a failing charging system. Told me it was time to get my ass home and not sit at lights with my brake light on (which can be as much of a draw as a headlight).
  16. jrodrims27
    jrodrims27 New Member
    San Diego
  17. Mind_Surfer
    VA
    Yes thank you Jrodrims, your post is what pointed me in that direction. I appreciate your help.
