vfr 87 (rc 24) tank petcock
Discussion in '1st & 2nd Generation 1983-1989' started by CARMINE, Jul 15, 2017.
  1. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Hi,
    the petcock of my 87 RC 24 (VFR 750 F) leaks on res/on position, after a long inactivity period.
    I have also a replacement part (external cover + movement). Whaich is the esiest way to relace ? Need to remove tank or whatelse ?
    Thank you for your help !
    Lamps from Carmine.
    On a fairly empty tank you could lean it way to the right and just replace. Once the selector is removed it's just 2 8mm head bolts. You might get some dribbles but it should go fast. Or remove tank and lay on right side.
    CARMINE likes this.
  3. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Hi capt
    Followed Your advice. Problem fixed
    Thank You!
