yup, new and asking dumb questions...
Discussion in 'Introductions' started by tblume, Dec 16, 2008.
  1. tblume
    tblume New Member
    :tinfoil3: can't flame me; tinfoil hat preserve us!
    got an 84 750 in need of a mechanically inclined hombre this fall, tore into it pretty good; Ebay forks, seals for same, sonic springs for same, adjusters are good but have the preload caps too, brake pads, front tire, cbr shock and daugherty's adapter, (he rebuilt that & added a spring for my fat arse,) top end oiling kit, set the valves, and now I'm looking at the clutch that was sticky clunky grabby and generally grumpy when cold but smoothed out when warmed up and ridden for 10-15 minutes. ideas?:unsure:
  2. jev.
    jev. over there
    So, what's the question? Are you asking why the clutch is grabby until warmed up? If so, you're probably gonna need to replace it.
  3. derstuka
    San Diego, CA
    TIG OLE BITTIES....WHAT?!!! YEP YEP! :stripper:
  4. tblume
    tblume New Member
    I hope that's your wife....lucky dog you:twitch:
    I need to pull it apart and look at the friction disks for something obvious, I have a haynes book to help there but maybe folks here have run into the same thing and it's a matter of just putting in a good moto specific oil or something easy, we'll see
  5. VT Viffer
    VT Viffer New Member
    South Carolina
    Does this bike have a hydraulic clutch? Time for a drain and refill.
    Mmmm titties.:tongue:
  6. midias
    midias New Member
    Rochester NY
    Huh what boobs :shocked:
    But seriously how are the clutch hydraulics well when was the last time the fluid was bleed and changed?
  7. tblume
    tblume New Member
    yes hydromatic clutchamajig, no clue on when the PO did any work, when I got it the fork seals were puking, of course the pads were shot, the R shock was frozen solid, oil looked fresh (probably quick change for quick sell) and the front tire was showing the air inside in places, so I guess PM work was minimal if any. clutch hydro is next on my list after I mike the disks..
