'06 wont turn on
Discussion in 'General VFR Discussions' started by hans, Apr 19, 2020.
  1. hans
    hans New Member
    Winterized bike last July with relatively new battery. Had to charge it yesterday which makes sense given the freezing winter and time. Bike started and ran for 5 minutes. Today battery not strong enough to start bike so put back on charger. Hour later the trickle indicator was green - turned key and... nothing. Only thing on is the clock. No instruments/lights/etc. Left manual in the city. Help! ;). Thanks folks.
  2. hans
    hans New Member
    And also - any advice on how to get the main fuse cover off. #$^#%
  3. Arno71
    Arno71 New Member
    Netherlands
    Niceville FL
    I hope you checked the kill switch?
    Also check the ground on the blue/grey connector behind the left fairing.
    Besides that, do you have a multimeter to perform measurements?
  4. NorcalBoy
    Take the battery somewhere and get it load tested before you do anything.
  5. RllwJoe
    RllwJoe Insider
    Did you winterize the bike in July in the USA? Even in Alaska I would imagine that July would be a bit early to winterize your motorcycle.
    I second NorcalBoy's recomendation - to charge the battery out of the bike then have it load tested.
