16000 Mile Valve inspection-here goes nothing!
Discussion in '8th Generation 2014-Present' started by Vulcanator, Aug 9, 2020.
  1. fink
    fink Member
    Welsh are affectionately knows as sheep shaggers or Taffs.
    Well at least if its done its done. I will tell you this, when you go to collect it ask what the clearances are and what the ones in the Vtec ( the expensive bit of checking). In a perfect world you will be handed a sheet of paper with the clearances and shim sizes for each valve/Bucket Vtec
    #41
    Thumbs likes this.
  2. Bubba Utah
    Bubba Utah Member
    Utah
    I did not see this before I went and picked her up yesterday, and I was in a rush, but good advise. She runs great and a cool shop and friendly true bikers (all wearing tats, Eating sunflower seeds and the token friendly bitbull included) that run it with staff of both sport and cruizers as a go to. $773 + Stupid Utah sales tax and I am good because it is better than $1300 from the dealer. I kn0w that I did it early and could have saved some money, But time is something I dont have so I paid for it. The only complaint I had was that they did not clean up the silicon around the head gasket.
    • Valve adjustment 4 hrs labor -$392.00
    • two 12391-mcw-000 gaskets -$75.00
    • one 7.45 shim 1.85 - $6.00
    • Coolant system flush Labor .5 hours - $49
    • Ice Coolant- $22
    • Flush/ Bleed and replace Rear Brake/Clutch oils labor 1 hour -$98
    • Brake Fluid- $10
    • Oil Change Labor .5 hrs - $49
    • Amsoil Synthtic Oil - $52
    • Oil Filter $8 (I bought the racing hi-flo filter so I hope they used it;-))
    • Chain C-L-A .2 hrs - $20
    • Overall inspection of bolts, lines, fuel system, idle speed, etc Included
    • Checked the front shake after 90mph - no conclusions other than T30 evo front tire wear and not a steering stem, balance issue Included
    • Washed and waxed as well as tires cleaned and shiny tire stuff on them Included
    #42
  3. Bubba Utah
    Bubba Utah Member
    Utah
    Looks like they only changed one shim so obviously to early! Oh well, What's a Part Taff to do other than live and learn.
    #43
  4. Vulcanator
    Vulcanator New Member
    Portland, OR
    $773 + tax is not too shabby at all for all the work you had done. Looks like they only changed a normal valve shim. At least you have the peace of mind it's all done. Enjoy the ride. Just ordered a Corbin seat and backrest for my bike, and Corbin have turned it around much quicker than expected. I'll be getting the seat on Tuesday but due to work I won't be home until early April. Look forward to trying it out.
    #44
    Bubba Utah and VScot like this.
  5. PetePower
    PetePower New Member
    South Australia
    Great news Valve check now out to 38400kms as I have just clicked over 25000kms.
    Few years back I did the valve clearance check on my ol Yammy YZF600 which was relatively easy, except for the head gasket staying in place. I ended up putting a fine bead of grease around the head cover to hold gasket in place, then a quick wipe away of the excess once torqued.
    #45
