1983 vf750f stuck in 3rd gear
Discussion in '1st & 2nd Generation 1983-1989' started by Rj3nk, Nov 19, 2012.
  1. Rj3nk
    Rj3nk New Member
    Ontario, Ca.
    Went on a ride this weekend, 5 miles in to the ride i came up to a signal and when it turned green, i took off and almost stall it, it was i 3rd gear and will not shift up or down. shift lever and linkage is good. it got to be internal. I do not have a manual yet, byt looks like i will be needing one. where sould i start, sprock side or clutch side?
  2. TOE CUTTER
  3. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Probably a bent shift fork. Since your clutch still disengages that means it's ok. The bad news is that you will have to pull the engine and split the cases to fix this. Sorry!
  4. hopit88
    hopit88 New Member
    I had spring #17 or #18 in Toe's link that broke in my 750 that messed things up a bit. Worth a look.
  5. TOE CUTTER
    I have had several of those springs break where it contacts the arm so sticking a fork in it may be way too premature. Still could be an easy fix, kinda depends on if the lever is stuck or not. If it is stuck you have screwed the pooch.........a dalmatian in case you were wondering.
  6. JamieDaugherty
    Fort Wayne, IN
    Worth pulling the clutch side case cover for a quick inspection. Best to not get hopes up too far though, at least that is my experiences.
  7. Rj3nk
    Rj3nk New Member
    Ontario, Ca.
    Thanks Guys,
    wish me luck... hoping its a spring.
    Going to wrench on her.
    Ren
  8. TOE CUTTER
    :doh: ..........he did not say if the lever was stuck.
  9. Rj3nk
    Rj3nk New Member
    Ontario, Ca.
    It was the #17 spring... got parts ordered. next problem can't find the broken spring parts inside oil pan, have been fishing with a magnet for awhile, looks like i will be pulling the oil pan.
  10. hopit88
    hopit88 New Member
    That's awesome. Pays to check the simple things first.
  11. TOE CUTTER
    SWEET! Glad it was a simple one for a change.
  12. taylor65
    taylor65 New Member
    florence, al.
    I had that spring break in a 700 nighthawk once. Bad thing about that model was you had to pull the motor out of the frame to get the clearance needed to change it out. I also had to pull the oil pan to find the broken spring. If I remember right I found it in the oil screen. I remember thinking Honda could have made it much easier to get to. Glad you figured it out.
  13. Sic Semper Tyrannis
    Sic Semper Tyrannis New Member
    Denver
    So, I have this same problem. My #17 spring broke. I was able to fish it out of the oil pan. But I don't know where to get a replacement. I contacted Bikebandit, and they say it is no longer available. Does anyone know where it can be ordered, or am I destined for the never ending search? I see Rj3nk was able to order one back in 2012.
    Any help would be much appreciated!
  14. Allyance
    Allyance Insider
    East Bay, California
    I probably have one if you can send me a photo or link to a parts fiche.
