1984-86 Honda VF500F
Discussion in 'Specifications' started by michael, Jan 13, 2006.
  1. michael
    michael Administrator Staff Member
    Kihei, Maui, Hawaii
    Model: 1984 Honda VF500F
    ENGINE
    Type: 498 cc, V4, 4-stroke
    Cooling: Liquid
    Bore x Stroke: 60.4 mm x 44 mm
    Compression Ratio: 11:1
    Power: 70 hp (52.2 kW) @ 12000 rpm
    Torque: 43 Nm (31.7 ft. lbs) @ 10500 rpm
    Transmission: 6 speed
    WHEELS
    Front Tire: 100/90-16
    Rear Tire: 110/90-18
    Front Brakes: Dual disc
    Rear Brakes: Single disc
    DIMENSIONS
    Length: 2070 mm (81.5 inches)
    Width: 760 mm (29.9 inches)
    Height: 1175 (46.3 inches)
    Seat Height: 800 mm (31.5 inches)
    Wheelbase: 1420 mm (55.9 inches)
    Fuel Capacity: 4.5 gallons
    Dry Weight: 185 kg (407.9 pounds)
    Curb Weight: 206.0 kg (454.2 pounds)
    Top Speed: 199.0 km/h (123.7 mph)
    Original List Price: $2,898 US
    DESCRIPTION
    The "Miniceptor" as it is affectionately called ran basically unchanged (except for graphics) until replaced by the CBR600 Hurricane in '87. Like the original '83 VFR750, it sported a 16" front wheel, 18" rear wheel, silver alloy painted Steel Perimeter (Twin Spar) frame (Similar to GSXR or Honda NS500 frame), Single rear shock w/ 2 sided Alloy swingarm, 1/2 upper fairing with chin or belly fairing, chain driven cams, 4/2 exhaust.
    A great little bike, it begged to be ridden hard. You did not "feel" fast on this bike then you would look down at the speedometer and either impress/scare yourself at your corner speeds.
  2. droopydawg
    droopydawg New Member
    Lake Forest, Illinois
    The '86 VF500F has the Anti-Dive mechanisms too, right? Or perhaps the bike I just recently picked up, the PO installed VFR750 forks. I see no mention of the anti-dive in the specs above, which is what i am asking. thanks
  3. flameface
    flameface New Member
    New England
    My '84 had anti dive brakes.
  4. synaptik
    synaptik New Member
    north of dallas Texas
    anyone got an online service manual for the 85 vf500f?
  5. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    yes the 500s came with anit-drive
