1984 Honda VF400F
Discussion in 'Specifications' started by michael, Jan 13, 2006.
  1. michael
    michael Administrator Staff Member
    Kihei, Maui, Hawaii
    Model: 1984 Honda VF400F
    ENGINE
    Type: 399 cc, V4, 4-stroke
    Cooling: Liquid
    Bore x Stroke: 55 mm x 42 mm
    Compression Ratio: 11:1
    Power: 55.5 hp (41.4 kW) @ 12500 rpm
    Torque: 35.5 Nm (26.2 ft. lbs) @ 10500 rpm
    Transmission: 6 speed
    WHEELS
    Front Tire: 100/90-16
    Rear Tire: 110/90-18
    Front Brakes: Single disc
    Rear Brakes: Single disc
    DIMENSIONS
    Length: 2060 mm (81.1 inches)
    Width: 750 mm (29.5 inches)
    Height: 1160 (45.7 inches)
    Seat Height: 780 mm (30.7 inches)
    Wheelbase: 1405 mm
    Ground Clearance: 160 mm (6.3 inches)
    Fuel Capacity: 4.5 gallons
    Dry Weight: 175 kg (358.8 pounds)
    Original List Price: $6,929 US
    DESCRIPTION
    Same as the 1982 VF400F, but with a full-covered cowling.
