1984 vf500 not starting
Discussion in '1st & 2nd Generation 1983-1989' started by christbennett429, Mar 5, 2010.
  1. christbennett429
    christbennett429 New Member
    Austin, tx
    Thanks for the reply, sorry the fuel flows freely as its clear in the lines and gravity fed now. The bike will start and rough for about 4 seconds then shuts off, now this isnt a consistent thing but have gotten it to do this about 3 or 4 times not in a row though. Chris
  2. tinkerinWstuff
    The next step then would be to verify that you do not have any vacuum leaks. Check for any uncovered vacuum nipples, unconnected vacuum lines, check/verify the vacuum line that is or used to go to the fuel petcock. Check the carb boots. Check that the vacuum manifold ports on the head are either capped or connected to something.
    i.e. each cylinder's intake has a threaded spot near where the carb boots are as a vacuum source. Some of these will be plugged with a screw, some will have a vacuum line like the one going to the fuel petcock. Your engine may or may not still have that line if a previous owner modified your fuel petcock. Maybe I have a photo.
    How many times did I say petcock??
  3. christbennett429
    Austin, tx
    The petcock has the middle of the diaphragms cutout and the vacuum line looped to the other vacuum line on the petcock as per Jamie Daugherty walk-through sorry if I spelled that wrong. I will check now but think all the lines are capped. Chris
  4. tinkerinWstuff
    It would take a lot of vacuum issues to keep an engine with proper spark and decent carbs from at least running, if not poorly.
    Assuming there are no gapping holes sucking wind instead of fuel,
    and assuming you have good spark, timing, and properly routed plug wires,
    either the engine is flooding out or it's not getting fuel.
    You've checked flow to the carbs but's it's hard to know what happens from the poin the fuel line connects to the carbs and the spark plug. Not sure if your plugs were wet when you pulled them out?
    If it's me, I pour 1 tablespoon or so of fuel down each of the four carb intakes and crank it over to see if it runs for a few seconds. Basically same drill I was going for with the starting fluid. Keep a portable fire extinguisher nearby (legal jargon in case my lawyer is watching). If you pour a tablespoon down there and she cranks, cranks, cranks without firing; try twisting the throttle a 1/4 turn or so.
    If it tries to run during this test, you likely have a carb problem and she just isn't getting fuel. You'll have to pull the carb assembly off again and check the fuel screens above the needle/seat valves (and a bunch of other checks while you have the assembly back on the bench).
    If it doesn't fire during this test then your bike is straight out of the twilight zone. For it not to run you'd either have to be flooded (but there's no tank on the bike while you try this so it can't continue to flood it out), missing spark but you said there's spark, or lack of compression but you said that's good too. You said there's good fuel flow to the carb assembly so there can't be a problem with the fuel petcock, plugged filters, or shutoff diaphram.
  5. christbennett429
    Austin, tx
    The plugs were wet when I pulled them. I did pore some marvel mystery oil down in the cylinders a time ago and let it set. IT wasnt much but could it be somewhat hydro locked or no? Chris
  6. tinkerinWstuff
    No, not really. But the wetness on the plug could be a oil residue and not fuel. You said in post #10 you were going to replace and gap the plugs. Did this happen?
  7. christbennett429
    Austin, tx
    Yes plugs werent replaced, misplaced the proper tool for the new plugs but cleaned the electrodes and gapped the champion plugs that were in the bike so they should be ok. I dont like the champion plugs but shouldnt have a problem. Chris
  8. tinkerinWstuff
    I'd like to see real compression test results on this motor with a gauge.
    You could have 40psi of compression (cold) and she'd blow your finger off the plug hole while cranking but it wouldn't be enough to maintain combustion and run on it's own.
    Have a buddy/neighbor/relative with a gauge? Maybe your local auto parts store rents one.
  9. christbennett429
    Austin, tx
    Im determined to find one, im guessing one with a 12mm adapter? Im going to do an oil change on friday and hopefully buy the gauge. Also the oil isnt watery but has no viscosity to it whatsoever im sure this doesnt help things. Stupid I know as much mechanical skill as I have but I guess never worked on motorcycles so its alittle scary though same in basic operation. Chris
  10. tinkerinWstuff
    Wouldn't recommend wasting time or money doing an oil change until you've completed the compression test. If the test results are low then you just threw all that oil away.
    The engine will run without oil in it at all (although not for too aweful long) so that's not your problem. Low viscocity could be from being watered down with fuel. Changing oil should be high on your list but I wouldn't spend money on filters etc until you figure this problem out. As long as there's something in there and she's somewhat slippery, a little cranking in the garage and a minute or two of idleing isn't going to do any damage.
    But that's just me.
  11. christbennett429
    Austin, tx
    Btw the carb boots are brand new, one looks like it might not be 100% seated to the head but it does make contact and is banded tight against it. I am looking to getting the correct gauge now, I have been tempted to buy one but have always been able to borrow one. I dont think the head gasket change would be too hard though the cam removal is a pain and making sure the timing is correct. Also if worse comes to worse im hoping its only the gaskets and not the piston rings. I am worried though as even with bad head gaskets it is probable it should start alittle. Thinking out loud I guess. Chris
  12. tinkerinWstuff
    I got my 500 because someone attempted to replace a cam, and then it would never run again.
    Next guy got it and found out the the PO set the cam timing off 90 deg. He fixed the timing and the motor sat on the bench.
    I bought the bike as a box of parts. Put it all together, got it running and it clattered like mad. Tore it back apart and found it had another bad cam and the 2nd PO who fixed the timing didn't gap the valves correctly.
    Anyway, if your bike has had someone elses fingers in there, it could just be that the valve timing is off. A compression test will help diagnose. Odd thing is, starting fluid will ignite without compression and if the valve timing were off, you should have got a flame ball out the exhaust or the intake if you were doing the test right.
    Time (and patience) will tell.
  13. christbennett429
    Austin, tx
    Ok update. I left the petcock to run overnight by mistake and just happened to try and crank the motor over for the sake of it just to see what it would do and it started up and ran and continued to run. Also the motor tries to die if I turn the choke low or off and there is smoke coming out of the back of the exhaust. Also the idle speed will fluctuate from time to time. What do you think? Chris
  14. squirrelman
    Carb cleaning is in order if you need choke to keep it running
  15. tinkerinWstuff
    What Super-Squirrel said.
    I thought you said in your OP that the carbs had been cleaned already?
    there is a lot of detail to go thru in a carb cleaning so I'd recommend you consider sending the carb assembly to someone with experiance.
  16. christbennett429
    Austin, tx
    I just had the carbs out and cleaned them completely including the sliders and the float bowls and plus the jets.
  17. squirrelman
    HOW completely you cleaned the carbs is related to your level of experience......first time, you probably missed several details.
  18. tinkerinWstuff
    Get your money back then.
    Bottom line is, the engine isn't getting fuel unless it's choked. Sooooo, your low speed jet, and/or the idle port, are plugged. You can clean the bowls and the sliders all day long and it doesn't matter. You can pull the jets too but it doesn't matter. What gets plugged is the cast passageways in the carb bodies. There are also fuel screens above the needle/seat assembly.
  19. TOE CUTTER
    I have been dragging my feet on posting but this does sound like a carb issue as Squirrel said. Smaller bikes are much more likely to suffer from little issues and making sure the the jets are clear and clean is the only next logical step.
  20. christbennett429
    Austin, tx
    I took the carbs apart completely and cleaned the sliders completely and made sure they were smooth also the bores were they go were clean also. I took the float bowls off and with a whole can of carb cleaner cleaned out the carbs and had a little brush to clean all the inside including the floats. I also took the idle and main jet out and made sure they were completely clean. I could spray a stream through them and see light through them also the secondary portion of the jet with all the holes. Finally I cleaned the holes through the carb and took the a/f screws out and cleaned. They are set currently at 2 and a half turns. Tell me what else I missed you can only learn by doing.
