1984 VF500F with 86 engine complete rebuild
Discussion in '1st & 2nd Generation 1983-1989' started by rcthirty, May 9, 2024.
    Rear downpipes already installed?
    #41
  2. rcthirty
    rcthirty New Member
    No but I haven't put the valve covers on so I should have acc
    #42
  3. rcthirty
    rcthirty New Member
    Valve covers on.jpg Exhaust pipes on, Valves lash checked again and valve covers on. I pored oil in the top end friction points and buttoned it up. I'm wondering if I should have waited until I spin it to make sure the oil pump is suppling the top end. Should I do that first ? I suppose I can spin the crank with a battery connected to the starter.
    #43
    Bazza likes this.
    Slightly loosen one of the oil line bolts on the head when you crank it and you'll know.
    #44
    Bazza likes this.
  5. rcthirty
    rcthirty New Member
    I'm getting oil supply to the top end now. I ended up poring about 6oz of oil into the rear supply banjo with a tiny tube I had. Took an hour for it to filter it down. Waiting on o-rings for the carb float bowls before I mount the carbs.
    #45
  6. rcthirty
    rcthirty New Member
    I went ahead and installed sprocket and chain and sprocket cover. Then installed peg bracket and gear shifter. sprock.chain,cover and gear shift installed.jpg
    #46
    Bazza likes this.
    Do you run GP shift pattern? 1 up, 5 down?
    #47
  8. rcthirty
    rcthirty New Member
    It can be changed easily. I'd like to try it.
    #48
  9. squirrelman
    useless except on a race bike, dangerous if you ride other bikes.
    #49
  10. rcthirty
    rcthirty New Member
    Well it really won't matter if I can't get these rear carbs to stop leaking. I confirmed the the valve and seat stop the flow. I raised the float height to 7mm. I put new float bowl gaskets Captain-80 suggested ordering. BTW they're great. Thanks for the source. It still leaks from both rear float bowl covers. I see no other gas leaks except there. I'm out of ideas except to order floats, float bowl covers, or god forbid carbs.
    #50
    Are you ABSOLUTELY sure it is the bowls leaking? And not a fuel tube above them?
    If the floats don't have fuel in them, then they are fine. You can switch locations of the bowls themselves also to rule out them, but that's is very likely not the problem either.
    #51
    Bazza and jstehman like this.
    Oh.... one other thing...
    Are you checking your float heights with the carbs completely flipped over on a bench? You have to rotate the carbs in a manner that the float is hanging and rotate a little more to where the float tab just contacts the spring loaded button on the float valve WITHOUT compressing it. You will get wrong measurements and heights if you are not.
    #52
  13. sixdog
    sixdog Insider
    Maybe I missed it but are you bench testing the carbs ?
    #53
  14. rcthirty
    rcthirty New Member
    Yes I'm bench testing and if I'm not mistaken adjusting your way Capt would make the float height lower.
    #54
  15. squirrelman
    floats never go bad (maybe sum idiot could destroy the tab), and new ones will need adjustment. did you recently install new needles and seats ?
    #55
  16. rcthirty
    rcthirty New Member
    Yes I have new ones. I've tried the old ones and even swapped the needles and seats from the front carbs. No difference.
    #56
  17. sixdog
    sixdog Insider
    Maybe check the float bowls for integrity? I would think it's a worn o-ring in the fuel delivery circuit...
    #57
    Whether it affects your problem in this instance or not, it's not "my" way, it's the way you do it.
    #58
  19. rcthirty
    rcthirty New Member
  20. rcthirty
    rcthirty New Member
    Yes I know it's the right way and I've worked on many carbs doing it the right way. I'm sorry I used that phrase. I meant no disrespect.
    #60
