1984 VF500F with 86 engine complete rebuild
Discussion in '1st & 2nd Generation 1983-1989' started by rcthirty, May 9, 2024.
    3 seconds. Not a "Short".
    Bazza likes this.
  2. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Agree....sounded great!
  3. rcthirty
    rcthirty New Member
    Still sounds good. ;-) And cell phone audio is harsh!
    Cool man.
  5. rcthirty
    rcthirty New Member
    I've been working on fabricating a petcock for my gas tank. I rigged this up to attach a feed to it.
  6. rcthirty
    rcthirty New Member
    So this is what I came up with as a petcock.
    rc24dk likes this.
    Pretty clever, but what sealant did you use?
    I should also ask, did you incorporate an o-ring in your design?
  8. rcthirty
    rcthirty New Member
    This Permashield sealant and Liquid tape. The liquid tape is awesome for rubber repair. Better then glue sticks IMO and much easer to apply.
    Bazza likes this.
    I HIGHLY recommend you add some fuel and let the tank sit over some newspapers for at least a week.
    You will likely need to incorporate an o-ring into your design.
    jstehman likes this.
  10. rcthirty
    rcthirty New Member
    I have o-rings on both screws and the tank filter shaft
    Captain 80s likes this.
    Cool! I would still do a test of course.
  12. rcthirty
    rcthirty New Member
    Will do
  13. rcthirty
    rcthirty New Member
    Just to be clear Mike, I put an o-ring on the tank filter then installed it in the gas tank. Then I coated around the o-ring with the liquid tape. Then I did the same with the two screw o-rings. I then coated the entire bottom of the block I made with the liquid tape. After securing the block to the gas tank I filled in the sides with the permashield.
    Got it. The oring around the strainer tube is key, as long as it is getting squished a bit. Not sure what the orings around the bolts are doing.
    If gas gets by the main oring, there isn't a sealant that will hold off fuel forever.
    Like I said, pretty clever! Hope it works.
  15. rcthirty
    rcthirty New Member
    the o-rings around the screws are just for extra security. I should be mounting the tank soon. I'll know then.
    rc24dk likes this.
  16. rcthirty
    rcthirty New Member
    I had to order a quality inline petcock as the cheap Chinese one leaked. Now we're good.
    Bazza likes this.
  17. rcthirty
    rcthirty New Member
    WELL IT'S DONE !! I finally finished it. Made up some side panels and it's ready to ride when it warms up. Thanks to everyone that helped !!
    VF500 finished Right side.jpg Left side cover completed.jpg Left side cover completed.jpg
  18. rcthirty
    rcthirty New Member
  19. Captain 80s
    Very good. Enjoy when the weather warms up and give us a ride report.
    I am REALLY ready for some moto time myself.
