1986-87 Honda VFR700F
Discussion in 'Specifications' started by michael, Jan 29, 2006.
  1. michael
    michael Administrator Staff Member
    Kihei, Maui, Hawaii
    Model: 1986-87 Honda VF700F
    ENGINE
    Power: 76.03 BHP @ 11,000 RPM ('87)
    Torque: 42.06 ft-lb @ 7500 RPM ('87)
    Transmission: 5 speed
    WHEELS
    Front Tire: 110/90-V16
    Rear Tire: 130/80-18
    Front Brakes: Dual disc
    Rear Brakes: Single disc
    DIMENSIONS
    Length: 2120 mm (83.5 in)
    Width: 730 mm (28.7 in)
    Height: 1170 mm (46.1 in)
    Wheelbase: 1480 mm (58.3 in)
    Dry Weight: 198 kg (436 lb)
    Original List Price: $4,498 US
    DESCRIPTION
    This U.S. "Tariff Beater" model was almost identical to the 1986 VFR750F with the only external difference being no 750 designation in the graphics (on the lower side fairings), just the VFR and Interceptor name. Colors were white w/red & blue stripes (R/W/B). Inside difference was shorter stroke, different cams, and ignition timing. The R/W/B models had the "Factory" goldish engine covers as found on the 750.
  2. varminter
    varminter New Member
    TePuke NI NZ
    Hi,My 1986 VFR 700 F Inteceptor as in the photo has a six speed close ratio transmision.
    Cheers.
  3. deano845
    deano845 New Member
    Cromwell, Otago, New Zealand
    Yea mine is six speed aswel. Could be that some were 5 speed. Possably a low spec model
  4. jamey2466
    jamey2466 New Member
    This is my 86 vfr700f and it is a six speed to
